CrowPanel ESP32 3.5-inch with ESP-IDF
IDF Version V5.5.4 Ivgl: 8.3.11
Overview
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with ESP-IDF.
Hardware Preparation
CrowPanel ESP32 3.5'' HMI Crowtail-DHT20 Crowtail-LED Dupont-wire
CrowPanel-ESP32-3.5inch CROWTAIL-DHT20 CROWTAIL-LED 4-PIN-FEMALE-WIRE
BUYNOW BUYNOW BUYNOW BUYNOW
GetStartedWithSquareLine
  1. Open the SquareLine Studio and create a project.
    Note:
    Set the name of the project, set the screen resolution to 480*320, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
  2. After creation, enter the following interface with a blank background.
  3. In the "Assets" area, click "ADD FILE TO ASSETS" to add custom images or icons.
    Note:
  4. Add background.
  5. Add Label widget to display temperature and humidity.
    You can set the font colour and other attributes in STYLE SETTING→STYLE(MAIN).
  6. Add Button widget to control the LED.
  7. Add events to buttons.
    Select "clicked" as the trigger condition, select a trigger event in "Action". It will be modified in the generated program to achieve the LED control function.
  8. Export UI files.
    3
    3
    Then click "APPLY CHANGES".
    You can click download to download the export UI files we provided.
Build the Project with ESP-IDF
Get Started with ESP-IDF
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
You can click download to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Library introduction
#include <lvgl.h>
#include <DHT20.h>
#include <TFT_eSPI.h>
#include <Arduino.h>
#include "ui.h"
  • #include <lvgl.h>: Library for UI interaction.
  • #include <DHT20.h>: The library of temperature and humidity sensors.
  • #include <TFT_eSPI.h>: Screen driven library.
  • #include <Arduino.h>: This is the core Arduino header file. It must be included when using the Arduino framework.
  • #include "ui.h": is a custom header file that contain UI-related functions or definitions.
Code Explanation
Basic Definition
  • Set the screen cache
#define SCREEN_WIDTH  480
#define SCREEN_HEIGHT 320
#define LVGL_TICK_PERIOD 5
uint16_t calData[5] = {353, 3568, 269, 3491, 7};
TFT_eSPI lcd = TFT_eSPI();
DHT20 dht20;
int led = 0;
// Screen buffer (recommended to be 1/10 to 1/4 of screen size)
#define DRAW_BUF_SIZE (SCREEN_WIDTH * SCREEN_HEIGHT / 8)
lv_color_t draw_buf[DRAW_BUF_SIZE];
// LVGL display and input device
static lv_disp_draw_buf_t disp_draw_buf;
static lv_disp_t *disp;
static lv_indev_t *indev;
// Real-time temperature and humidity label objects
lv_obj_t *temp_label;
lv_obj_t *humi_label;
  • Automatically refresh temperature and humidity data in real time.
// Sensor update
void update_sensor_values() {
  int temperature = dht20.getTemperature();
  int humidity = dht20.getHumidity();
  // If you have corresponding labels in ui.h, you can uncomment the following to update the UI:
  lv_label_set_text_fmt(temp_label, "%d", temperature);
  lv_label_set_text_fmt(humi_label, "%d", humidity);
  Serial.print(temperature);
  Serial.println(" °C");
  Serial.print("Humidity: ");
  Serial.print(humidity);
  Serial.println(" %");
  • Touch reading function
// Touch reading
uint16_t touchX, touchY;
void my_touchpad_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data) {
  (void)indev_drv;
#ifdef TOUCH_CS
  static bool was_pressed = false;
  bool pressed = false;
  if (lcd.getTouch(&touchX, &touchY)) {
    pressed = true;
    data->point.x = touchX;
    data->point.y = touchY;
  } else {
  if (pressed && !was_pressed) {
    Serial.printf("Touch DOWN: %u, %u\n", touchX, touchY);
  } else if (!pressed && was_pressed) {
    Serial.println("Touch UP");
  was_pressed = pressed;
#else
#endif
  • Refresh function
// Refresh function
void my_disp_flush(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p) {
  uint32_t w = lv_area_get_width(area);
  uint32_t h = lv_area_get_height(area);
  lcd.pushImage(area->x1, area->y1, w, h, (uint16_t *)color_p);
  lv_disp_flush_ready(disp_drv);
Setup Part
  Serial.begin(115200);
    // IO pin setup
    pinMode(25, OUTPUT);
    digitalWrite(25, LOW);
  // Initialize I2C
  Wire.setPins(22, 21);
  Wire.begin();
  dht20.begin();
  // Initialize LCD
  lcd.begin();
  lcd.setRotation(1);        // Adjust screen orientation if needed
  lcd.setSwapBytes(true);    // Swap RGB and BGR data
  lcd.fillScreen(TFT_BLACK);
  delay(300);
  // Backlight control
  pinMode(27, OUTPUT);
  digitalWrite(27, HIGH);
#ifdef TOUCH_CS
  lcd.setTouch(calData);
#endif
  // Initialize LVGL
  lv_init();
  // Create display driver
  lv_disp_draw_buf_init(&disp_draw_buf, draw_buf, NULL, DRAW_BUF_SIZE);
  lv_disp_drv_init(&disp_drv);
  disp_drv.hor_res = SCREEN_WIDTH;
  disp_drv.ver_res = SCREEN_HEIGHT;
  disp_drv.draw_buf = &disp_draw_buf;
  disp = lv_disp_drv_register(&disp_drv);
  // Register touch input device
  indev = lv_indev_drv_register(&indev_drv);
  // Initialize UI
  ui_init();
  temp_label = ui_Label1;
  lv_label_set_text(temp_label, "--");
  humi_label = ui_Label2;
  lv_label_set_text(humi_label, "--");
Main Program Part
  static unsigned long last_update = 0;
  if (millis() - last_update > 2000) {
    update_sensor_values();
    last_update = millis();
  digitalWrite(25, led ? HIGH : LOW);
  lv_tick_inc(LVGL_TICK_PERIOD);
  lv_timer_handler();  // Handle LVGL tasks
// Entry point for ESP-IDF
extern "C" void app_main() {
  initArduino();
  setup();
  while (true) {
    loop();
    vTaskDelay(pdMS_TO_TICKS(5));
Setup board
5
6
Download the program
Connect the ESP32 Display to the PC and compile the program.
7
After confirming the serial port, select the UART mode.
8
After the program is successfully downloaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO25), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
