CrowPanel ESP32 2.8-inch with ESP-IDF¶
IDF Version V5.5.4 Ivgl: 8.3.11
Overview¶
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with ESP-IDF.
Hardware Preparation¶
| CrowPanel ESP32 2.8'' HMI | Crowtail-DHT20 | Crowtail-LED | Dupont-wire |
Open the SquareLine Studio and create a project.
Note:
Set the name of the project, set the screen resolution to 320*240, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
Add background.
You can set the font colour and other attributes in STYLE SETTING→STYLE(MAIN).
Add events to buttons.
Select "clicked" as the trigger condition, select a trigger event in "Action". It will be modified in the generated program to achieve the LED control function.
Export UI files.
Then click "APPLY CHANGES".
Build the Project with ESP-IDF¶
Get Started with ESP-IDF¶
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
You can click
to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Library introduction¶
#include <lvgl.h>: Library for UI interaction.#include <DHT20.h>: The library of temperature and humidity sensors.#include <TFT_eSPI.h>: Screen driven library.#include <Arduino.h>: This is the core Arduino header file. It must be included when using the Arduino framework.#include "ui.h": is a custom header file that contain UI-related functions or definitions.
Code Explanation¶
Basic Definition
- Set the screen cache
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
static lv_color_t buf1[ screenWidth * screenHeight / 8 ];
TFT_eSPI lcd = TFT_eSPI();
DHT20 dht20;
uint16_t calData[5] = {189, 3416, 359, 3439, 1};
extern "C" int led = 0;
- Touch reading function
uint16_t touchX, touchY;
bool touched = lcd.getTouch( &touchX, &touchY, 400);
if ( !touched )
else
data->point.x = touchX;
data->point.y = touchY;
- Refresh function
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
lcd.startWrite();
lcd.setAddrWindow( area->x1, area->y1, w, h );
lcd.pushColors( ( uint16_t * )&color_p->full, w * h, true );
lcd.endWrite();
lv_disp_flush_ready( disp );
Setup Part
extern "C" void app_main()
initArduino();
Serial.begin(115200);
pinMode(25, OUTPUT);
digitalWrite(25, LOW);
Wire.begin(22, 21);
Wire.setClock(100000);
delay(100);
if (dht20.begin() != 0) {
Serial.println("DHT20 init failed");
lv_init();
lcd.begin();
lcd.fillScreen(TFT_BLACK);
delay(300);
pinMode(27, OUTPUT);
digitalWrite(27, HIGH);
lcd.setRotation(1);
lcd.setTouch( calData );
lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * screenHeight / 8 );
lv_disp_drv_init( &disp_drv );
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
uint32_t last_sensor_ms = 0;
Main Program Part
while (1)
lv_tick_inc(10);
lv_timer_handler();
uint32_t now = millis();
if (now - last_sensor_ms >= 1000) {
last_sensor_ms = now;
int temperature = 0;
int humidity = 0;
if (dht20.readTempHumidity(&temperature, &humidity) == 0) {
char dht_buffer[8];
snprintf(dht_buffer, sizeof(dht_buffer), "%d", temperature);
lv_label_set_text(ui_Label1, dht_buffer);
snprintf(dht_buffer, sizeof(dht_buffer), "%d", humidity);
lv_label_set_text(ui_Label2, dht_buffer);
digitalWrite(25, led ? HIGH : LOW);
vTaskDelay(pdMS_TO_TICKS(10));
Setup board¶
Download the program¶
Connect the ESP32 Display to the PC and compile the program.
After confirming the serial port, select the UART mode.
After the program is successfully downloaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO25), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
