4 SD card stores images and displays them locally
Welcome to the application tutorial of Lesson 4. The effect to be achieved in this lesson is to store the images that need to be displayed on the SD card and display them on the CrowPanel ESP32 Advance HMI.
1 Select the photos you want to display on the browser and save them on the desktop (the save path can be customized)
2 Modify the resolution of the image based on the size of the product you are using.
2
Here, for large-sized products, I will take the 2.4-inch product as an example to introduce how to modify the resolution of images.
The resolution of the 2.4-inch product is 320x240.
3
4
5
Adjust the pixel to 2.4-inch screen resolution: 320x240
6
Click confirm
7
8
9
10
11
12
3 Insert the SD card containing this saved image into your CrowPanel ESP32 Advance HMI
13
(2.4 inch, 2.8 inch, 3.5 inch products can be directly inserted for use)
14
(After inserting the SD card, turn the function switch to 1 0 mode (TF Card mode) for 4.3-inch, 5.0-inch and 7.0-inch.)
4 Open the code we provide, and you only need to modify the path and name of the image you saved
15
16
Modify the path of the image you saved
17
Here, my path is the five images in the current path on the SD card
So the path of my image is the current path "/" plus the image name (1. bmp)
18
Then display the image in the loop and set the resolution size
(different sizes have different resolutions)
19
5 Configure the runtime environment and burn code
(Before burning, please replace the relevant library files according to different sizes.
How to replace, details in Lesson 2)
20
21
6 Phenomenon display
22
23
24
25
26
7 Code reference
7.0 inch、5.0inch、4.3inch
#include "pins_config.h"
#include "LovyanGFX_Driver.h"
#include <Wire.h>
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
/* Expand IO */
#include <TCA9534.h>
TCA9534 ioex;
#define SD_MOSI 6
#define SD_MISO 4
#define SD_SCK 5
#define SD_CS 0 //The chip selector pin is not connected to IO
// The image name you stored on the SD card
#define IMAGE_1 "/1.bmp"
#define IMAGE_2 "/2.bmp"
#define IMAGE_3 "/3.bmp"
#define IMAGE_4 "/4.bmp"
#define IMAGE_5 "/5.bmp"
SPIClass SD_SPI = SPIClass(HSPI);
LGFX gfx;
// Display text on the screen
void show_test(int lcd_w, int lcd_h, int x, int y, const char * text) {
  gfx.fillScreen(TFT_BLACK);
  gfx.setTextSize(3);
  gfx.setTextColor(TFT_RED);
  gfx.setCursor(x, y);
  gfx.print(text);
  Serial.begin(115200); // set baud rate
 // Init Display
  gfx.init();
  gfx.initDMA();
  gfx.startWrite();
  delay(500);
  Wire.begin(15, 16);
  delay(50);
  ioex.attach(Wire);
  ioex.setDeviceAddress(0x18);
  ioex.config(1, TCA9534::Config::OUT);
  /* Turn on backlight */
  ioex.output(1, TCA9534::Level::H);
  if (SD_init() == 0)
    Serial.println("TF_Card initialization succeeded");
    show_test(LCD_H_RES, LCD_V_RES, 350, 230, "SD_Card OK");
    delay(3000);
  } else {
    Serial.println("TF card initialization failed");
    show_test(LCD_H_RES, LCD_V_RES, 350, 230, "SD_Card failed");
    delay(3000);
  gfx.setRotation(2);
  Serial.println( "----- Setup done -----" );
 // Cycle printing each image
  Serial.println("Refreshing image...1");
  displayImage(SD, IMAGE_1, 800, 480);
  delay(5000);
  Serial.println("Refreshing image...2");
  displayImage(SD, IMAGE_2, 800, 480);
  delay(5000);
  Serial.println("Refreshing image...3");
  displayImage(SD, IMAGE_3, 800, 480);
  delay(5000);
  Serial.println("Refreshing image...4");
  displayImage(SD, IMAGE_4, 800, 480);
  delay(5000);
  Serial.println("Refreshing image...5");
  displayImage(SD, IMAGE_5, 800, 480);
  delay(5000);
// SD card initialization
int SD_init()
  SPI.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS);
  SD_SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
  if (!SD.begin(SD_CS, SD_SPI, 80000000))
    Serial.println(F("ERROR: File system mount failed!"));
    SD_SPI.end();
    return 1;
  else
    Serial.println("Card Mount Successed");
    Serial.printf("SD Size: %lluMB \n", SD.cardSize() / (1024 * 1024));
    // hspi->end();
  listDir(SD, "/", 2);
  Serial.println("**** TF Card init finished ****.");
  return 0;
Function: List files and subdirectories in the specified directory.
Parameters:
  - fs: The file system object used to operate on the file system.
  - dirname: A pointer to the name of the directory whose contents are to be listed.
  - levels: Specifies the depth of recursive listing of subdirectories.
void listDir(fs::FS & fs, const char *dirname, uint8_t levels) {
  Serial.printf("Listing directory: %s\n", dirname);
  File root = fs.open(dirname); // Open the specified directory.
  // If the directory cannot be opened.
  if (!root) {
    Serial.println("Failed to open directory");
    return;
  // If the opened item is not a directory.
  if (!root.isDirectory()) {
    Serial.println("Not a directory");
    return;
  File file = root.openNextFile(); // Open the next file in the directory.
  // While there are still files.
  while (file) {
    // If the current file is a directory.
    if (file.isDirectory()) {
      Serial.print("  DIR : ");
      Serial.println(file.name()); // Print the directory name.
      // If there are still levels of depth for recursion.
      if (levels) {
        listDir(fs, file.name(), levels - 1); // Recursively call the function to list the contents of the subdirectory, reducing the depth by 1.
    // If the current file is not a directory, i.e., a regular file.
    else {
      Serial.print("  FILE: ");
      Serial.print(file.name()); // Print the file name.
      Serial.print("  SIZE: ");
      Serial.println(file.size()); // Print the file size.
    file = root.openNextFile(); // Continue to open the next file in the directory.
  Function:
    - Display image from file
  Parameters:
    - filename: The name of the BMP image file
    - x: The x - coordinate on the screen to start printing the image
    - y: The y - coordinate on the screen to start printing the image
  Returns:
    - 0 if the image is printed successfully, 0 if the file cannot be opened
int displayImage(fs::FS &fs, String filename, int x, int y)
    File f = fs.open(filename, "r"); // Open the file for reading
    if (!f)
        Serial.println("Failed to open file for reading");
        f.close();
        return 0; // File open failed, return 0
    f.seek(54); // Skip the 54 - byte BMP file header
    int X = x; // representing the width of the image
    int Y = y; // representing the height of the image
    uint8_t RGB[3 * X]; // Storage space for RGB data of each row, 320 pixels, 3 bytes per pixel (RGB)
    for (int row = 0; row < Y; row++) // Iterate through each row of the image
        f.seek(54 + 3 * X * row); // Jump to the position of the current row
        f.read(RGB, 3 * X); // Read the RGB data of the current row
        gfx.pushImage(0, row, X, 1, (lgfx::rgb888_t *)RGB); // Display the data of the current row
    f.close(); // Close the file
    return 0;
3.5inch
#include <Wire.h>
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <Arduino.h>
#define SD_MOSI 6
#define SD_MISO 4
#define SD_SCK  5
#define SD_CS   7 //The chip selector pin is not connected to IO
LGFX gfx;
  gfx.setTextSize(3);
  gfx.print(text);
  Serial.begin(115200); //set baud rate
  // Init Display
  gfx.init();
  gfx.initDMA();
  gfx.startWrite();
  delay(500);
  pinMode(38, OUTPUT);
  digitalWrite(38, HIGH);
  if (SD_init() == 0)
    Serial.println("TF card initialization succeeded");
    show_test(LCD_H_RES, LCD_V_RES, 125, 135, "SD_Card OK");
    delay(3000);
  } else {
    show_test(LCD_H_RES, LCD_V_RES, 125, 135, "SD_Card failed");
    delay(3000);
  gfx.setRotation(2);// 7
  displayImage(SD, IMAGE_1, 480, 320);
  delay(5000);
  displayImage(SD, IMAGE_2, 480, 320);
  delay(5000);
  displayImage(SD, IMAGE_3, 480, 320);
  delay(5000);
  displayImage(SD, IMAGE_4, 480, 320);
  delay(5000);
  displayImage(SD, IMAGE_5, 480, 320);
  delay(5000);
int SD_init()
    SD_SPI.end();
    return 1;
  else
  return 0;
Parameters:
    if (!root) {
      return;
      return;
    while (file) {
          if (levels) {
      else {
  Function:
  Parameters:
  Returns:
  if (!f)
    f.close();
  return 0;
2.8inch、2.4inch
#include <Wire.h>
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#define SD_MOSI 6
#define SD_MISO 4
#define SD_SCK 5
LGFX gfx;
  gfx.setTextSize(3);
  gfx.print(text);
  Serial.begin(115200);//set baud rate
  // Init Display
  gfx.init();
  gfx.initDMA();
  gfx.startWrite();
  delay(500);
 if (SD_init() == 0)
    show_test(LCD_H_RES, LCD_V_RES, 75, 150, "SD_Card OK");
    delay(3000);
  } else {
    show_test(LCD_H_RES, LCD_V_RES, 75, 150, "SD_Card failed");
    delay(3000);
  gfx.setRotation(2);
  displayImage(SD, IMAGE_1, 320, 240);
  delay(5000);
  displayImage(SD, IMAGE_2, 320, 240);
  delay(5000);
  displayImage(SD, IMAGE_3, 320, 240);
  delay(5000);
  displayImage(SD, IMAGE_4, 320, 240);
  delay(5000);
  displayImage(SD, IMAGE_5, 320, 240);
  delay(5000);
int SD_init()
    SD_SPI.end();
    return 1;
  else
  return 0;
Parameters:
    if (!root) {
        return;
        return;
    while (file) {
            if (levels) {
        else {
  Function:
  Parameters:
  Returns:
    if (!f)
        f.close();
    return 0;
