DIY TECHOS
  • 5 Projects
  • 14 Followers
  • Oct 11,2024
XRC PRO: Open-Source RC Transmitter and Receiver System
XRC PRO is a powerful, open-source RC transmitter and receiver system using STM32 and NRF24L01. It features real-time control.
  • Easyeda pro
  • KeiluVision
  • Flasher-Stm32
Overview
The XRC PRO is an advanced, open-source RC transmitter and receiver system designed to offer professional-level performance in a compact and customizable package. Built around the STM32F103C8T6 microcontroller and the NRF24L01 wireless transceiver module, the XRC PRO provides precise, real-time control for various RC applications like drones, cars, and boats. With a compact design, robust functionality, and user-friendly interface, the XRC PRO is an ideal tool for both hobbyists and professionals.
Key features
     Feature                                                          Description
OLED Display Displays real-time signal strength, settings, battery percentage, and control data.
Trim Buttons & Rotary Encoder Fine-tune controls and navigate through menus effortlessly for enhanced usability.
Multi-Menus Intuitive menu system for adjusting channel settings, polarity, and output modes.
PPM & SBUS Outputs Offers versatile output options to support various RC receivers for expanded functionality.
NRF24L01 Power Control Adjustable signal strength settings for short and long-range control.
Stick Calibration Real-time calibration of sticks with visual feedback on the OLED display for precise adjustments.
Compact Receivers Two efficient options for 8-channel PWM+PPM and PPM+SBUS outputs, designed for optimal performance.
Throttle Mode Choose between left or right throttle hand mode for personalized control preferences.
PC Simulator Compatibility Utilize the PPM output for playing simulators on a computer, with the option to toggle PPM output on/off.
Express ELRS Integration Utilize PPM output with an ELRS adapter for compatibility with various ELRS modules.
Buzzer On/Off Mode Easily toggle the buzzer on or off for audio feedback during operations.
Adjustable Setting Unit Customize the unit of measurement for settings (e.g., degrees, percentages) according to user preference.
Battery Voltage Calibration Calibrate battery voltage display to reflect accurate percentage readings for better monitoring.
Reset to Default Settings Quickly restore all settings to default through a simple menu option for ease of use.
Tech Specs
Component                                  Specification
Microcontroller STM32F103C8T6 ARM® Cortex®-M3:
• ARM® Cortex®-M3 core up to 72 MHz
• 20KB onboard SRAM
• 64KB Flash
Wireless Module NRF24L01 GT24 Mini:
• 2.4 GHz ISM band
• High data rate up to 2 Mbps
• Supports multiple data pipes
Display 0.96" OLED Display:
• Displays signal strength, battery percentage, and control data
Power AMS117 3.3V Regulator,
Power input from 7.4V to 12V (2S to 3S LiPo battery)
Weight 200g (without battery)
Dimensions 160 mm x 120 mm x 40 mm (without antenna)
Enclosure DJI Phantom 2 Remote (or customizable based on user preference, can use Arduino joysticks as an alternative)
Components
The XRC PRO is designed with readily available, off-the-shelf components, making it easy for others to replicate or modify. Below are the key components:
Transmitter
No. Component Description/Note Quantity  Buy Link
1 STM32F103C8T6 Desolder components from the STM32F103C8T6 development board, then solder to the transmitter PCB 1 Click to Buy
2 NRF24L01 GT24 Mini Wireless Transceiver Module 1 Click to Buy
3 E11 Rotary Encoder (ENC) Rotary Encoder for menu navigation 1 Click to Buy
4 SMD 8MHz Crystal (3225) Crystal Oscillator for STM32 1 Click to Buy
5 FC-135 32.768kHz Crystal Real-Time Clock (RTC) Crystal 1 Click to Buy
6 CH340C SMD USB to Serial Converter 1 Click to Buy
7 Y1 (8050) NPN Transistor 2 Click to Buy
8 1AM (3904) NPN Transistor 1 Click to Buy
9 0.96" OLED Display For displaying transmitter data (status, menus, etc.) 1 Click to Buy
10 10k Ohm Resistor (SMD) SMD Resistor for various circuits 4 Click to Buy
11 1k Ohm Resistor (SMD) SMD Resistor for various circuits 4 Click to Buy
12 100nF Capacitor (SMD) Capacitor for signal filtering 20 Click to Buy
13 Buzzer Audio feedback for transmitter alerts 1 Click to Buy
14 AMS117 (3.3V Voltage Regulator) Provides 3.3V to various components on the board 1 Click to Buy
15 10uF Capacitor For power stabilization and filtering 2 Click to Buy
16 Male Headers Used for connecting modules or components to the PCB 30 Click to Buy
17 DJI Phantom 2 Remote Used as the enclosure for the transmitter, or use any suitable remote/joystick  1
Find yourself any suiteable broken transmitter for enclosure and sticks.
Receivers(PWM+PPM)
1 STM32F103C8T6 Desolder components from the STM32F103C8T6 development board, then solder to the receiver PCB 1 Click to buy
3 SMD 8MHz Crystal (3225) Crystal Oscillator for STM32 1 Click to Buy
4 1AM (3904) NPN Transistor 1 Click to Buy
5 AMS117 (3.3V Voltage Regulator) Provides 3.3V to various components on the board 1 Click to Buy
6 10uF Capacitor For power stabilization and filtering 2 Click to Buy
7 100nF Capacitor (SMD) Capacitor for signal filtering 4 Click to Buy
8 Male Headers Used for connecting modules or components to the PCB 30 Click to Buy
Receivers(PPM+SBUS)
1 STM32F103C8T6 Desolder components from the STM32F103C8T6 development board, then solder to the receiver PCB 1 Click to Buy
Schematic and PCB Layout
The XRC PRO has multiple PCBs and it consists of three main PCBs: the Transmitter PCB, the 8-channel PWM+PPM Receiver PCB, and the PPM+SBUS Receiver PCB. Each PCB was carefully designed for space efficiency and optimal performance.
Transmitter PCBs
The Transmitter PCB is built around the STM32F103C8T6, NRF24L01 module, OLED display, and various input buttons (trim, menu, encoder). The schematic includes connections for power management (5v to 3.3v), data lines for the OLED, and button inputs for settings navigation etc.
Schematic
Aspect                                                    Description
STM32 Connections STM32 is connected to NRF24L01 via SPI, OLED via I2C, and buttons for control inputs.
Power Supply Circuit Features a stable power supply using a 5V to 3.3V step-down regulator, ensuring reliable operation.
 PPM Output Pin PPM output pin is mapped for direct use with simulators or external RC receivers.
PCB Layout
Aspect                                                       Description
Size Optimization Minimized PCB size using almost all components in SMD package to achieve a professional and compact design.
Decoupling Capacitors Added 100nF decoupling capacitors to each channel to reduce noise and smooth signal performance.
Compact Design Designed to fit within the DJI Phantom 2 remote enclosure, ensuring a sleek and practical design.
Button & Display Placement All buttons, display, and rotary encoder pads are neatly arranged for ease of use and functionality.
Signal Routing Careful routing of SPI and I2C lines to avoid interference and ensure clean signal transmission.
2D and 3D Preview
Final Result
2D and 3D Preview
Final Result
Rotary Encoder+Switch
2D and 3D Preview
Final Result
Trim Buttons
2D and 3D Preview
Final Result
Type C Jack
2D and 3D Preview
Final Result
Receciver PCBs
The 8-channel receiver supports both PWM and PPM outputs. It is based on the NRF24L01 and STM32F103C8T6 for signal decoding and generation.
Schematic
Aspect                                                          Description
Signal Decoding Decodes signals from the NRF24L01 transceiver using the SPI interface for reliable data communication.
8 PWM Output Pins Provides 8 PWM output pins for controlling multiple servos, enhancing RC model functionality.
PPM Output Pin PPM output pin designed for connecting to flight controllers or other compatible devices.
PCB Layout
Aspect                                                           Description
Compact Design Compact PCB layout for seamless integration into various RC models, optimizing space usage.
Efficient Signal Routing Efficient routing of signal and power lines to minimize noise and avoid signal interference.
2D and 3D Preview
Final Result
The PPM+SBUS receiver is another compact design focused on supporting more advanced control protocols. It also features the STM32F103C8T6 for signal processing and output.
Schematic
Aspect                                                          Description
SBUS Output Pins SBUS output pin designed for connecting to flight controllers or other compatible devices.
PCB Layout
Aspect                                                              Description
2D and 3D Preview
Final Result
Visual and Physical Connections
I’ve designed a detailed, color-coded connection schematic for all inputs and outputs, making it easy for anyone to assemble the XRC PRO transmitter and receivers. Additionally, I’ve included high-quality these images in PDF format, which you can download below.
Transmitter
Receiver(PWM+PPM)
Receiver(PPM+SBUS)
Firmware Overview
The XRC PRO's firmware is developed in Keil uVision using the CMSIS framework for STM32. It is fully open-source, with modular code to allow easy customization and extension of the system's capabilities. The main focus of the firmware is on handling communication between the transmitter and receivers, as well as managing the various control inputs.
Here the whole files in KeiluVision:
Below are the functions broken down from the main execution code, organized into smaller functional blocks. These functions are intended to be modular and handle specific tasks like initialization, signal strength calculation, display management, and event handling:
1. setup()
This function initializes all the necessary hardware peripherals and sets up the system for operation.
    // Initialize the delay function for timekeeping
    delayInit();
    // Initialize USART for serial communication
    usart1Init();
    // Initialize timers for PWM and other timing-related functions
    timer2Init();
    timer3Init();
    // Initialize DMA for memory transfers
    dmaInit();
    // Initialize ADC for analog reading (e.g., battery level)
    adcInit();
    // Initialize NRF24L01 for wireless communication
    if (nrf24l01Init() == NRF_OK) {
        nrf24l01SetModeTX(); // Set NRF to transmit mode
    } else {
        // Handle NRF24L01 initialization error
        beepError();
    // OLED display initialization and show start-up screen
    oledInit();
    oledShowLogo();
    // Perform throttle self-check and configure NRF24L01 power mode
    throttleSelfCheck();
    // Set up low-power mode if necessary
    lowPowerModeConfig();
2. loop()
The main loop that continuously runs during operation. It handles the display updates, signal strength checks, and key events.
    // Handle clock alarms and time display on the OLED
    handleClockAlarm();
    // Update OLED display with throttle values and battery percentage
    displayThrottleValues();
    displayBatteryLevel();
    // Update signal strength display
    updateSignalStrength();
    // Check for key events and menu navigation
    keyEventHandle();
    // Handle menu events, if any
    menuEventHandle();
    // Small delay to avoid constant polling
    delay(50);
3. keyEventHandle()
Handles user input through key presses. This function updates throttle settings and processes navigation within the menu.
void keyEventHandle() {
    if (isKeyPressed(KEY_LEFT)) {
        // Adjust throttle channel for left-hand throttle
        adjustThrottleLeft();
    if (isKeyPressed(KEY_RIGHT)) {
        // Adjust throttle channel for right-hand throttle
        adjustThrottleRight();
    // Update OLED display with new throttle or menu setting
    oledRefresh();
    // Save user data or preferences (e.g., throttle setting)
    saveUserDataToFlash();
4. addSignalStrengthSample()
Adds a new sample to the signal strength buffer and maintains a moving average of signal strength.
void addSignalStrengthSample(int newSignalStrength) {
    // Add new signal strength to the sample buffer
    signalStrengthBuffer[sampleIndex] = newSignalStrength;
    // Update sample index for circular buffer
    sampleIndex = (sampleIndex + 1) % SIGNAL_STRENGTH_BUFFER_SIZE;
5. getAverageSignalStrength()
Calculates the moving average of the signal strength based on the collected samples.
int getAverageSignalStrength() {
    int sum = 0;
    for (int i = 0; i < SIGNAL_STRENGTH_BUFFER_SIZE; i++) {
        sum += signalStrengthBuffer[i];
    return sum / SIGNAL_STRENGTH_BUFFER_SIZE;
6. displaySignalIcon()
Displays the signal strength icon on the OLED based on the signal strength percentage.
void displaySignalIcon(int signalStrengthPercent) {
    if (signalStrengthPercent >= 75) {
        oledDrawIcon(iconSignal100);
    } else if (signalStrengthPercent >= 50) {
        oledDrawIcon(iconSignal75);
    } else if (signalStrengthPercent >= 25) {
        oledDrawIcon(iconSignal50);
    } else if (signalStrengthPercent > 0) {
        oledDrawIcon(iconSignal25);
    } else {
        oledDrawIcon(iconSignalOff);
 7.NRF24L01 Initialization
Initializes the NRF24L01 module and sets it in transmit mode.
void nrf24l01InitAndCheck() {
        // Set NRF24L01 to transmit mode
    } else {
        // Handle NRF24L01 error by beeping and showing error message
        beepError();
        oledShowErrorMessage("NRF24L01 ERROR");
8.Sending Data Packets: sendDataPacket()
This function creates a 32-byte data packet and sends it using the NRF24L01 module. The packet contains a data header and channel values (PWM data).
u8 sendDataPacket(void)
    u8 chPacket[32]; // Array to hold the data packet
    u16 t = 0;
    u8 sendIsOK; // Flag to check if sending is successful
    for (t = 0; t < 16; t++)
        if (t == 0) // Add data header (0x00)
            chPacket[2 * t] = 0x00;
            chPacket[2 * t + 1] = 0x00;
        else if (t <= chNum) // Add PWM channel data
            chPacket[2 * t] = (u8)(PWMvalue[t - 1] >> 8) & 0xFF; // High byte of 16-bit PWM value
            chPacket[2 * t + 1] = (u8)PWMvalue[t - 1] & 0xFF;    // Low byte of 16-bit PWM value
        else // Fill unused bytes with 0xFF (padding)
            chPacket[2 * t] = 0xFF;
            chPacket[2 * t + 1] = 0xFF;
    sendIsOK = NRF24L01_TxPacket(chPacket); // Transmit the packet
    return sendIsOK; // Return status of the transmission (success or failure)
9.Signal Strength Calculation: getSignalStrength()
This function measures the signal strength by sending multiple packets and calculating the percentage of successful transmissions.
int getSignalStrength(void)
    const int totalPackets = 40; // Total number of packets to send
    int successfulPackets = 0;   // Counter for successful transmissions
    if (setData.NRF_Mode == ON) // If the NRF mode is ON
        NRF24L01_TX_Mode(setData.NRF_Power); // Set NRF to transmit mode
    else
        NRF24L01_LowPower_Mode(); // Otherwise, set it to low-power mode
    // Loop to send multiple packets
    for (int i = 0; i < totalPackets; i++)
        if (sendDataPacket() == TX_OK) // If the packet was sent successfully
            successfulPackets++; // Increment success counter
        delay_us(700); // Short delay between transmissions
    // Calculate signal strength as a percentage of successful packets
    int signalStrength = (successfulPackets * 100) / totalPackets;
    return signalStrength;
10. updateSignalStrength()
Updates the signal strength display and checks if the receiver is connected. It also adds a new sample to the signal strength buffer.
void updateSignalStrength() {
    // Get current signal strength from NRF24L01
    int currentSignalStrength = nrf24l01GetSignalStrength();
    // Add the sample to the signal strength buffer
    addSignalStrengthSample(currentSignalStrength);
    // Calculate the average signal strength
    int avgSignalStrength = getAverageSignalStrength();
    // Display the corresponding signal strength icon
    displaySignalIcon(avgSignalStrength);
    // Check if receiver is connected
    if (avgSignalStrength > SIGNAL_STRENGTH_THRESHOLD) {
        receiverConnected();
    } else {
        receiverDisconnected();
11. menuEventHandle()
Handles the user interface menu and responds to user input for changing settings.
void menuEventHandle() {
    // Check if a specific menu item is selected
    if (isMenuItemSelected(MENU_ITEM_PWM_ADJUST)) {
        adjustPWMSettings();
    if (isMenuItemSelected(MENU_ITEM_CHANNEL_CALIBRATION)) {
        calibrateChannels();
    // Refresh OLED display with updated menu or settings
    oledMenuRefresh();
12. Battery Voltage Display
Updates the battery level icon and percentage on the OLED based on the battery voltage.
void displayBatteryLevel() {
    float batteryVoltage = readBatteryVoltage();
    int batteryPercent = convertVoltageToPercentage(batteryVoltage);
    // Display the battery icon and percentage on the OLED
    oledDrawBatteryIcon(batteryPercent);
    if (batteryVoltage < BATTERY_WARNING_THRESHOLD) {
        // Beep to warn low battery
        beepWarning();
13. Clock and Alarm Handling
Handles the clock and alarm functionality, beeping when an alarm is triggered.
void handleClockAlarm() {
    // Check if the clock alarm is active
    if (isAlarmActive()) {
        // Beep if the alarm time is reached
        beepAlarm();
        // Display alarm icon on the OLED
        oledDrawIcon(iconAlarm);
    // Update the time on the OLED display
    displayCurrentTime();
These functions represent the core operations of the system, which handles initialization, user input, signal strength monitoring, display updates, and more. Each function focuses on a specific aspect of the overall operation, making the code more modular and easier to manage.
Firmware Uploading
To upload the firmware to the transmitter and receivers, follow the connection diagram below. It shows how I connected the CH340 USB-to-TTL adapter to both the transmitter and receivers.
Connections
Transmitter
There are two methods of uploading code into transmitter.First,you can directly upload the code via USB TYPE-C Interface.  Second,you can upload the code with the help of USB to TTL (ch340 driver).
Rceiver(PWM+PPM)
Receiver(PPM+SBUS)
Software
Download and install the STMicroelectronics Flash Loader Demonstrator software: Click to download
Steps
Follow:
  1. Plug the USB serial converter into the PC.
  2. Press the reset button on the STM32 board.
  3. Select the COM port in the software.
  4. Click 'Next,Next and Next.
  5. Select Download to device.Click on 3 dots and select the hex file.
  6. Select Global Erase.After that Click on Next
  7. Within 15 seconds, the code will be uploaded to the device.
  8. After finsihed.Click Close.
  • Transmitter Code (opensource)
    Transmitter_Code_1890216864671fbd88d1972.rar
    Download(386)
  • Receiver Code (opensource)
    Receiver_Code_164446902667220564e1d9c.rar
    Download(197)
  • Transmitter Hex file
    Transmitter_17817271767226350bbacb.rar
    Download(155)
  • Receiver Hex file
    Receiver_14961823796722637343c88.rar
    Download(126)
  • Transmitter and Receivers visual connections Schematic
    Transmitter_and_Receivers_visual_connections_Schematic_1936228011671fbec47569a.pdf
    Download(305)
  • Transmitter Schematic (pdf)
    TRANSMITTER_1110271523671fbf6a912b4.pdf
    Download(224)
  • Receiver (PWM+PPM) Schematic (pdf)
    RECEIVER_PWM_PPM_297194851671fbff082d7d.pdf
    Download(183)
  • Mini Receiver (PPM+SBUS) Schematic (pdf)
    MINI_RECEIVER_PPM_SBUS_1930561513671fc02162170.pdf
    Download(145)
  • Transmiter Gerber File
    Transmitter_gerber_817836462671fc34e7ee42.zip
    Download(96)
  • RECEIVER (PWM+PPM) gerber
    RECEIVER-_PWM_PPM_gerber_1864876203671fc37db11c4.zip
    Download(99)
  • RECEIVER (PPM+SBUS) Gerber file
    RECEIVER-_PPM_SBUS_gerber_527240692671fc3c679fe2.zip
    Download(90)
  • Transmitter Trim Switches Gerber file
    Trim-Switches_124411281367220855d704c.zip
    Download(76)
  • Transmitter Menu Switches Gerber file
    Menu-Switches_257047536672208e3644bb.zip
    Download(118)
  • Transmitter Rotary enc+Sw Gerber file
    Rotary-enc_Switch_170378089867220922b9364.zip
    Download(74)
  • Transmitter Type-C Jack Gerber file
    Type-C-Jack_70442404467220952dcbbb.zip
    Download(73)
  • Easyedapro schematic and pcb project files (opensource)
    ProPrj_XRC_PRO_2.4_2024__2024-11-07_1916554060672c641ccd581.rar
    Download(136)
15.5k
27
11
187
  • Comments( 11 )
  • Like( 27 )
  • Amazing bro.i have not such a highly detailed project before.And thanks for sharing this as opensource
    Oct 31,2024 2 comments
    Reply
  • First time i have seen such a great project.btw,can i connect elrs module its ppm output
    Oct 31,2024 1 comments
    • DIY TECHOS 2024-11-03 01:23:42
      Yes,you can connect.but you need ppm to elrs adapter for this.
      Reply
    Reply
  • Is it compatible with different FC like pixhawk2.4.8 and cube orange adsp carrier board ?
    Jul 15,2025 1 comments
    Reply
  • Hello, I made this Shamka project, but I made it with Arduino like this project, and it gives more range, exactly the same as the NRF module. The settings in Arduino are like this, but in your project I didn't understand where I should edit it: radio.setDataRate(RF24_250KBPS); radio.setPALevel(RF24_PA_MAX);
    Aug 22,2025 1 comments
    Reply
  • hi my pwm receiver throtle channel not responce...please help
    Dec 01,2025 0 comments
    Reply
  • hi i want to ask where you put pins of menu buttons cant find it
    Mar 10,2026 0 comments
    Reply
