cris
  • 72 Projects
  • 20 Followers
  • Oct 09,2024
Traffic Lights Circuit using NE555
Small circuit, well known.
  • NE555P
  • Kicad
Here's a clever circuit using two 555's to produce a set of traffic lights for a model layout. The animation shows the lighting sequence and this follows the Australian-standard. The red LED has an equal on-off period and when it is off, the first 555 delivers power to the second 555. This illuminates the Green LED and then the second 555 changes state to turn off the Green LED and turn on the Orange LED for a short period of time before the first 555 changes state to turn off the second 555 and turn on the red LED. A supply voltage of 9v to 12v is needed because the second 555 receives a supply of about 2v less than rail. This circuit also shows how to connect LEDs high and low to a 555 and also turn off the 555 by controlling the supply to pin 8. Connecting the LEDs high and low to pin 3 will not work and since pin 7 is in phase with pin 3, it can be used to advantage in this design.
I did not arrange the LEDs in line because I will use wires to solder them.
P.S. I am not the original author of this circuit, I just draw it.
Source: http://www.555-timer-circuits.com/traffic-lights.html
12.8k
14
  • Like( 14 )
