Grovety
  • 3 Projects
  • 6 Followers
  • Apr 18,2025
Simple Weather Station on CrowPanel Advance
A ready-to-use weather station. Quick setup: flash the prebuilt firmware and start testing in under a minute, no coding required. Open-source and customizable for your own weather-based projects. Firmware and source code available on GitHub.
Goods
This is a lightweight, open-source weather station project designed for the CrowPanel Advance. It displays detailed weather information from openweather.com and is ready to test in under 1 minute.
✅ Quick Start in 2 Steps:
  1. Grab your CrowPanel Advance
  2. Flash the precompiled firmware from GitHub — no setup needed: https://github.com/Grovety/CrowPanel_OpenWeather/tree/main/firmware
💡 Why Use It?
  • Testable in under 1 minute
  • Open-source — extend or repurpose for your own weather-related projects
  • Simple and reliable — ideal for both hobbyists and developers
🌦️ Features:
  • Current temperature and “feels like” temperature
  • Cloudiness, wind speed, pressure, humidity
  • Sunrise and sunset times
  • Hourly forecast for the next 12 hours
  • Daily forecast for the next 4 days
⚙️ Settings:
Temperature and pressure units (°C/°F, mmHg/hPa)
Manual and auto screen brightness control
Manual or automatic location detection
Wi-Fi connection setup via touch interface
👉 Precompiled firmware and source code are available on GitHub: https://github.com/Grovety/CrowPanel_OpenWeather/
  • https://github.com/Grovety/CrowPanel_OpenWeather
80
6
  • Like( 6 )
