RGB LED Strip Control System – Special Project Guide
🌟 PROJECT OVERVIEW
This document outlines an ESP32-based RGB LED control system with the following features:
2-channel PWM control (for red and green LED strips)
Automatic relay control after 7:00 PM (based on Turkey/Istanbul time)
Web interface and physical button control
HC-SR04-based presence detection for energy saving
LED dance mode based on Ankara weather data
🛠️ HARDWARE DETAILS
🔧 Required Components:
ESP32 DevKit v1 (1 unit)
IRFZ44N MOSFET (2 units - for red and green LED strips)
5V Relay Module (1 unit - room light control)
HC-SR04 (1 unit - distance measurement)
128x64 OLED (I2C) (GPIO6 SDA, GPIO7 SCL)
10K Potentiometer (2 units - GPIO4 and GPIO5)
Push Button (3 units - GPIO8, GPIO9, GPIO10)
10K Resistor (5 units - for pull-up)
Breadboard (1 unit)
Jumper Wires (20+ units)
🎛️ Pin Mapping:
⚡ Power Management:
ESP32: 120mA
LED Strip (12V): 2000mA
Relay Module: 80mA
HC-SR04: 15mA
OLED Display: 25mA
💾 SOFTWARE SETUP
📥 Required Libraries:
Core Libraries:
Adafruit_GFX (v1.10.12)
Adafruit_SSD1306 (v2.5.7)
WiFi (v2.0.0)
ESPAsyncWebServer (v3.1.0)
Time and Weather:
NTPClient (v3.2.1)
ArduinoJson (v6.19.4)
HTTPClient (v1.2)
⚙️ Code Structure:
🔄 Flashing Process (Arduino IDE):
Tools > Board > ESP32 Dev Module
Flash Mode: "QIO"
Flash Size: "4MB (32Mb)"
Partition Scheme: "Default 4MB"
Custom Settings:
🎛️ SYSTEM FEATURES
💡 LED Control System:
PWM Features:
8-bit resolution (0–255)
5kHz PWM frequency
Control:
POT1: Red LED intensity
POT2: Green LED intensity
⏱️ Time-Based System:
Timezone: Turkey/Istanbul (GMT+3)
Relay activation based on HC-SR04 after 7:00 PM:
Person detected: ON
No presence: OFF
🌤️ Weather Integration:
Ankara weather (OpenWeatherMap API):
GET https://api.openweathermap.org/data/2.5/weather?q=Ankara,TR&appid=YOUR_API_KEY&units=metric&lang=en
BTN3 (double click): Activates dance mode — LEDs synchronize based on weather
🖥️ USER INTERFACE
📺 OLED Menu Structure:
Main Menu
LED Values → Red: 0–255 / Green: 0–255
Relay Status → ON/OFF
MOSFET Status → PWM Setting / ON/OFF
🕹️ Button Controls:
BTN1:
Single Click: Menu Down
Double Click: Relay Status
Usage: POT1 Value Adjustment
BTN2:
Single Click: Menu Up
Double Click: MOSFET Status
BTN3:
Single Click: Confirm Selection
Double Click: Dance Mode
Usage: Toggle Options
🌐 Web Interface:
Endpoints:
→ Homepage -
/relay/on
→ Turn Relay ON -
/relay/off
→ Turn Relay OFF
🔧 TROUBLESHOOTING GUIDE
🚨 Common Issues:
LEDs Not Working:
Check MOSFET gate resistor (10K–100Ω)
Verify 12V power supply
Lower PWM frequency (try 500Hz)
HC-SR04 Inaccurate Readings:
WiFi Connection Problems:
📊 Serial Monitor Test Commands:
SYSTEM INFO
→ System Information -
LED TEST RED 255
→ LED Test -
RELAY TOGGLE
→ Relay Test -
SENSOR READ
→ Sensor Test
📈 ADVANCED SETTINGS
⚙️ EEPROM Configuration:
0x00
: WiFi SSID (32 bytes) -
0x20
: WiFi Password (64 bytes) -
0x60
: LED Settings (16 bytes) -
0x70
: Timing (32 bytes)
📜 LICENSE:
CERN-OHL-S-2.0
🤝 SPONSORS
📞 CONTACT & SUPPORT
Email: info@makerpcb.com.tr
Website: https://makerpcb.com.tr
Issue Tracking: GitHub Issues
This document covers all project details. For updates, follow the GitHub project page:
🔗 https://github.com/hamzadenizyilmaz/RGB-Control-System-with-ESP32-C6
