Elecrow community is a shared platform and we are not responsible for any design issues.
closed
Luc Paquin
Published: Sep 21,2024
Project #30 - UNIHIKER - MEMS VOC - Mk05
ccc ccc
Copyright Info
Attribution-NonCommercial-ShareAlike (CC BY-NC-SA)
Read More⇒
  147
  2
  • UNIHIKER
    DFRobot
    X 1 fenxiang
  • Fermion: MEMS VOC Gas Detection Sensor
    DFRobot
    X 1 fenxiang
  • USB Battery Pack
    X 1 fenxiang
  • USB 3.0 to Type-C Cable
    DFRobot
    X 1 fenxiang
  • Python
https://www.donluc.com/?p=4133
https://youtu.be/rwrBm-ZCIos
https://edu.dfrobot.com/makelog-314859.html
https://www.hackster.io/neosteam-labs/project-30-unihiker-mems-voc-mk05-fe80d8
#DonLucElectronics #DonLuc #UNIHIKER #VOC #Display #IoT #Project #Debian #Python #Thonny #DFRobot #Fritzing #Programming #Electronics #Microcontrollers #Consultant
Fermion: MEMS Volatile Organic Compounds VOC Gas Detection Sensor
Fermion: MEMS Volatile Organic Compounds VOC Gas Sensor employs state-of-the-art microelectromechanical system (MEMS) technology, endowing the sensor with compact dimensions, low power consumption, minimal heat generation, short preheating time, and swift response recovery. The sensor can qualitatively measure VOC gas concentration and is suitable for indoor air quality detection, fresh air system, air purifier and other application scenarios. Kindly remove the protective film before usage. Gas detected: ethanol, formaldehyde, toluene, etc. Detection range: 1-500 ppm. It is advisable to preheat the module for at least 24 hours.
DL2409Mk05
1 x UNIHIKER
1 x Fermion: MEMS VOC Gas Detection Sensor
1 x USB Battery Pack
1 x USB 3.1 Cable A to C
UNIHIKER
ADC - 21
VIN - +5V
GND - GND
DL2409Mk05p
DL2409Mk05p.py
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
Luc Paquin – Curriculum Vitae - 2024
https://www.donluc.com/luc/
Web: https://www.donluc.com/
DFRobot Luc.Paquin: https://edu.dfrobot.com/dashboard/makelogs
ELECROW: https://www.elecrow.com/share/sharepj/center/no/760816d385ebb1edc0732fd873bfbf13
TikTok: www.tiktok.com/@luc.paquin8
Don Luc
Luc Paquin
  • Like( 2 )
