Project #30 - UNIHIKER - AHT20 - Mk09
https://www.donluc.com/?p=4377
https://youtu.be/tU1lvjOKMfg
https://learn.dfrobot.com/makelog-314959.html
#DonLucElectronics #DonLuc #AHT20 #UNIHIKER #Display #IoT #Project #DFRobot #Fritzing #Programming #Electronics #Microcontrollers #Consultant
AHT20 - Temperature and Humidity Sensor
The AHT20 is a high-precision but low-cost temperature and humidity sensor, which is equipped with an improved MEMS semiconductor capacitive humidity sensor element. It features standard I2C interface and a wide voltage supply of 2 Volt - 5 Volt. And with simple peripheral circuit, it performs stably even in harsh environments in the measuring range of -40 - +85 Celsius. This sensor can be widely used for measuring the environmental temperature and humidity of home electronic equipment, the temperature and humidity of automobiles and so on.
DL2504Mk03
1 x UNIHIKER K10
1 x Switch
1 x USB 3.1 Cable A to C
DL2504Mk03p
DL2504Mk03p.mp
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
