Luc Paquin
  • 17 Projects
  • 8 Followers
  • Oct 01,2024
Project #29 - DFRobot - RTC - Mk31
  • FireBeetle 2 ESP32-C6
    DFRobot
    X 1 fenxiang
  • Adalogger FeatherWing - RTC + SD
    Adafruit
    X 1 fenxiang
  • CR1220 3 Volt Lithium Coin Cell Battery
  • Fermion: SHTC3 Temperature & Humidity Sensor
    DFRobot
    X 1 fenxiang
  • Fermion: 2.0" 320x240 IPS TFT LCD
    DFRobot
    X 1 fenxiang
  • GDL Line 10 CM
    DFRobot
    X 1 fenxiang
  • Gravity: Analog Soil Moisture Sensor
    DFRobot
    X 1 fenxiang
  • 3 AAA Battery Holder with On/Off Switch and 2-Pin JST
    Adafruit
    X 1 fenxiang
  • AAA Battery
  • SparkFun Solderable Breadboard - Large
    SparkFun
    X 1 fenxiang
  • USB 3.1 Cable A to C
    DFRobot
    X 1 fenxiang
https://www.donluc.com/?p=4152
https://youtu.be/qS-cBJ2GcK8
https://learn.dfrobot.com/makelog-314863.html
https://www.hackster.io/luc-paquin/project-29-dfrobot-rtc-mk31-a02a21
#DonLucElectronics #DonLuc #DFRobot #RTC #SD #ASM #SHTC3 #FireBeetle2ESP32C6 #Display #EEPROM #ESP32 #IoT #SparkFun #Adafruit #Arduino #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
Real-Time Clock
A Real-Time Clock (RTC) is an electronic device, most often in the form of an integrated circuit, that measures the passage of time. Although the term often refers to the devices in personal computers, servers and embedded systems, RTCs are present in almost any electronic device which needs to keep accurate time of day.
Although keeping time can be done without an RTC, using one has benefits:
-Reliably maintains and provides current time through disruptive system states such as hangs, sleep, reboots, or if given sufficient backup power, full shutdown and hardware reassembly, without the need to have its time set again.
-Low power consumption, important when running from alternate power.
-Frees the main system for time-critical tasks.
-Sometimes more accurate than other methods.
DL2409Mk08
1 x FireBeetle 2 ESP32-C6
1 x Adalogger FeatherWing - RTC + SD
1 x CR1220 3 Volt Lithium Coin Cell Battery
1 x Fermion: SHTC3 Temperature & Humidity Sensor
1 x Fermion: 2.0" 320x240 IPS TFT LCD
1 x GDL Line 10 CM
1 x Gravity: Analog Soil Moisture Sensor
1 x 3 AAA Battery Holder with On/Off Switch and 2-Pin JST
3 x AAA Battery
1 x SparkFun Solderable Breadboard - Large
1 x USB 3.1 Cable A to C
SCL - 20
SDA - 19
ASM - A1
LED - 15
DC - D2
CS - D6
RST - D3
VIN - +3.3V
GND - GND
DL2409Mk08p
DL2409Mk08p.ino
getDisplay.ino
getEEPROM.ino
getRTC.ino
getSHTC3.ino
getSoilMoisture.ino
setup.ino
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
Luc Paquin – Curriculum Vitae - 2024
https://www.donluc.com/luc/
Web: https://www.donluc.com/
DFRobot Luc.Paquin: https://edu.dfrobot.com/dashboard/makelogs
Hackster.io: https://www.hackster.io/neosteam-labs
ELECROW: https://www.elecrow.com/share/sharepj/center/no/760816d385ebb1edc0732fd873bfbf13
TikTok: www.tiktok.com/@luc.paquin8
Don Luc
259
2
  • Like( 2 )
