cris
  • 72 Projects
  • 20 Followers
  • Apr 10,2025
Programming CrowPanel ESP32 1.28 using Arduino IDE v2.3.4
I will present how I interacted with Elecrow and what I have from this provider, and I will start with CrowPanel ESP32 1.28-inch Round Display.
In what follows, I'll show you how I used the Arduino IDE v2.3.4 to upload some test programs to the CrowPanel ESP32 1.28-inch Round Display, so stay tuned, but first a few steps are required.
I assume you have used Arduino IDE before, if not, then google Arduino IDE and download the program.
  1. Download Arduino IDE from the official website and after you install it, open it and copy this as a text "https://espressif.github.io/arduino-esp32/package_esp32_index.json" to the place indicated in the pictures below.
  1. Usually, you will see Arduino Uno on the boards, but we don't use that, so we need to look for our board:
Now we can continue and upload a few sketches.
Push button test
The first program tested is one that shows a message in the Serial Monitor when we press the push button on the board:
// Define the pin number for the button
const int buttonPin = 1;  // The pin number where the button is connected
// Variable to store the current state of the button
int buttonState = 0;  // Variable to hold the button's state, initially set to HIGH (0)
  Serial.begin(115200);  // Initialize serial communication at a baud rate of 115200
  pinMode(buttonPin, INPUT);  // Set the button pin as an input
  // Read the current state of the button (HIGH or LOW)
  buttonState = digitalRead(buttonPin);
  // If the button is pressed (connected to ground, state is LOW)
  if (buttonState == LOW) {
    Serial.println("Button Press");  // Print a message when the button is pressed
  // If the button is not pressed, it is in the release state (HIGH)
  else {
    Serial.println("Button release");  // Print a message when the button is released
  // Note: This loop will continuously read the button state and print messages.
  // This may not be the desired behavior in all applications.
  // Consider adding a delay or using a debouncing method for the button.
And you can find a video on my YouTube channel: https://youtu.be/RAy8XQdcTJ0
Buzzer test
A slightly more "dynamic" program is this one through which the small built-in buzzer is put into operation:
// Define the pin number for the buzzer
#define BUZZER 3
  // This code runs once at the beginning of the program:
  pinMode(BUZZER, OUTPUT);  // Set the buzzer pin as an output
  digitalWrite(BUZZER, LOW);  // Initially set the buzzer to a low state (off)
  // This code runs repeatedly after the setup():
  tone(BUZZER, 100);  // Make the buzzer produce a tone at a frequency of 100 Hz
  delay(1000);  // Wait for one second
  tone(BUZZER, 0);  // Stop the buzzer from producing sound (frequency set to 0)
  delay(1000);  // Wait for another second
And you can find a video on my YouTube channel: https://youtu.be/oS1XGoXtpOA
To see even more tutorials, I suggest you access the links from the manufacturer of this device:
• https://www.elecrow.com/wiki/CrowPanel_ESP32_1.28-inch_Round_Display.html
• https://www.elecrow.com/wiki/ESP32_1.28-inch_Round_Display_Tutorial.html#tutorial-on-arduino-ide
I have tested almost all the sketches, the procedure is the same, what I have left is the program for the encoder, it is a small component assembled on a PCB and requires a tool like the one for the SIM card in phones, but I don't have a suitable one and I haven't been able to rotate it.
There will be more to come, I'm learning along with you. 🙂
Thank you for reading this blog and have great day!
1.4k
10
  • Like( 10 )
