Lily lee
  • 31 Projects
  • 21 Followers
  • Apr 02,2024
Mini Bench-scale
Using a weighing sensor and 3D printing to create a mini scale.
Mini Bench-scale
Supplies
  • Platform scale program and library files.
  • Step 1: 3D Design
    第 1 步:3D 设计
    • Design the size of the housing according to the size of the weighing sensor.
    • It's printed on a 3D printer
    • Step 2: Assemble
      第 2 步:组装
      第 2 步:组装
      第 2 步:组装
      第 2 步:组装
      3 More Images
      • Install the printed module and sensor
      Step 3: Debugging
      第三步:调试
      Download the program to the arduino,
      Start the program and put a 100-gram weight on it to see if it's accurate?
      Step 4: Modifying Library Files
      第四步:修改库文件
      第四步:修改库文件
      • Open the hx711.cpp file
      • Pull to the last "float Hx711::getGram()" position
      Modify the parameters in the red circle, adjust them appropriately, and then download and run the program to see if it is accurate.
      • Debug several times until it is accurate
Mini Bench-scale
14.9k
13
  • Like( 13 )
