Kapacita22uF
Macro keyboard
Hotswap macro keyboard with 6 keys, encoder, I2C OLED, IR TX, IR RX and LTC4054ES5-4.2
Macro keyboard
  • WCH-LinkE
  • Moun River Studio Community
IMK6K
-Hotswap macro keyboard with 6 keys and backlight( WS2812B-3535 OR WS2812B-2020)
-Encoder
-I2C OLED
-CH32X033
Soldered jumpers:
JP7 -U1 power
JLP1 -LED power
JOP1- OLED power
JP3- OLED SCL
JP4-OLED SDA
CH32X033 I/O:
PIN I/O FUNCTION
1-3 INPUT SW1-SW3 (PA6,PA7,PB1)
4 OUTPUT IR PWR ON/OFF (PB7)
5,6 USB USB D-, D+
7 POWER GND
8 PROG.PIN/OUTPUT SWDIO / LED PWR ON (PC18)
9 POWER VDD
10-12 INPUT SW4,SW5,SW6 (PA9,PA11,PA10)
13 OUTPUT RGB LED (WS2812B) (PC3)
14 AD CURRENT MEASUREMENT VIA USB (A0)
15 OUTPUT OLED SCL (PA1)
16 INPUT / OUTPUT OLED SDA(PA2)
17 INPUT ENCODER A (PA3)
18 PROG.PIN / OUTPUT SWDCK / IR TX (PC19)
19 INPUT ENCODER B (PA4)
20 INPUT ENCODER BUTTON / IR RX (PA5)
Materials:
Development material-CH32x03x
key code
USB-HID-Keyboard
External module:
Here is a link to a project with pins in which you can use the MCU you want:
EasyEDA module project only pins
Wiring jumpers when using an external module
Jumper Function Soldered
JP1 LED power on/off  NO
JP2 Fotoresistor NO
JP3 OLED SCL NO
JP4 OLED SDA NO
JP5 IR TX NO
JP6 IR RX NO
JP7 VDD on U1(CH32X033) NO
JG1 Direct Baterry - with GND YES If you do not want to measure   battery current ( INAB1 )
JIR1 Direct power connection for IR TX,RX YES If you do not want to turn on/off the power supply with the MCU (irpwron)
JLP1 Direct power connection for LEDs  YES If you do not want to turn on/off the power supply with the MCU (ledpwron)
JOP1 Direct power connection for OLED YES If you do not want to turn on/off the power supply with the MCU (oledpwron)
Video
Macro keyboard
758
7
  • Like( 7 )
