The board includes 10 APA102 addressable LEDs controlled by the on-board ATtiny85.
- Includes 10 APA102C LEDs controlled by the aforementioned ATtiny85. APA102C LEDs operate just like most addressable LEDs over a two-wire interface. The board ties that interface to the ATTiny85 and operates both the IC and LEDs at 3.3V logic.
Board Dimensions
LED Stick measures 1.00in x 3.60in (25.4mm x 91.44mm) with four mounting holes that fit a 4-40 screw.
With a quick software command we can change the I 2 C address of the ATTiny85
We can then control up to 100 LEDs (10 Qwiic LED Sticks) on a single bus!
