This board is perfect for a variety of IR remote receiving projects
1.Comes with mounting holes and cables for easier installation on enclosures and devices.
2.Features two optional IR receiver chips
3.Has ultra-sensitive wide range
4.Designed specifically for receiving 38KHz infrared remote control signals, a large number of 38KHz receiver sensors can work well on this breakout board
Pin
GND - common ground for power and data. It is the black wire on the JST PH cable.
V+ - power input for the infrared receivers. It is the red wire on the JST PH cable.
Sig - signal to your microcontroller. It is the white wire on the JST PH cable.
Signal LED
Signal LED - to the left of the JST PH connector is the signal LED, labeled Sig. It is the red LED. It will light up when an IR signal is read by the selected IR receiver.
Power LED
Power LED - to the right of the JST PH connector is the power LED, labeled ON. It is the green LED.
Raspberry Pi Wiring
Here's the Raspberry Pi wired to the receiver using a JST PH cable:
Pi 3V to receiver JST PH V+ (red wire)
Pi GND to receiver JST PH GND (black wire)
Pi GPIO5 to receiver JST PH Sig (white wire)
Here is how you'll wire the receiver to a Raspberry Pi with a breadboard:
Pi 3V to receiver V+ (red wire)
Pi GND to receiver GND (black wire)
Pi GPIO5 to receiver Sig (white wire)
