It is a digital multi-gas sensor that facilitates solutions for gas quality in life and can be used in smart homes, HVAC, building automation, etc.
- Has four sensor elements
- Independent hot plate control enables detection of volatile organic compounds (VOCs) including ethanol, toluene, hydrogen and oxidizing gases with exceptional sensitivity
- Supports intelligent algorithms for processing raw sensor measurements on-chip.
- These algorithms calculate CO2 equivalent, TVOC, air quality index (AQI), and perform humidity and temperature compensation and baseline management, all on the chip.
- Anyone can read raw sensor measurements for deeper customization
Example
How to give the Temperature and Relative Humidity Data for compensation
(Please note that temperature and relative humidity values will undergo some rounding)
1. Hardware connection
2. Go ahead and open Code File(You can find it at the end of the article)
3. After uploading the code, open the serial monitor and check the output. You should see something like the following
