This is a compact cardiac electronic board that can be used to monitor heart rate activity (but it cannot be used professionally to diagnose diseases)
We can use cables to connect the motherboard and the sensor. When the sensor starts to work, the board will amplify various signals from the heart, making it easier for us to
The cable has a 3.5mm audio jack and also has three small snap connectors
There is a small light on the board that will flash when the connection is successful.
Connection diagram
Notice
- Keep the sensor pad as close to the heart as possible.
- Make sure the RA and LA sensor pads are on the correct sides of the heart.
- Try not to move too much while measuring.
- Try a new pad every time you take a measurement. These pads lose their ability to carry signals in a variety of applications.
- Prepare and clean the area where you plan to apply the mat. This will help create a good connection (hair is not a good conductor).
- You may need to adjust the position of the sensor for different people
