eBUS Adapter Stick C6 provides an interface to a 2-wire eBUS with galvanic isolation and thus enables communication with an eBUS enabled heating, ventilation or solar system.
It is the smaller USB-stick like version of the previous adapter v5 sharing the very same technology with even smaller footprint (42x16mm), pluggable eBUS connection, on-board WIFI by using an ESP32-C6, support for USR-ES1 Ethernet module, and including a white enclosure.
Please refer to the documentation page for all details: adapter.ebusd.eu/v5-c6/stick
The v5 version of this interface was born to life early 2023 after several rounds of prototyping and is already in use by thousands of people. Since then, multiple design optimizations were performed including an eFuse for over voltage+current protection, and USB-C connection starting with the C6 version.
- Full galvanic isolation with zero power drawn from eBUS (class 0 as of eBUS specification)
- Flexible host connection via:
- USB
- WIFI with onboard PCB antenna
- Ethernet (with addon module USR-ES1)
- Full support for ebusd enhanced protocol
- Web-based configuration and updatability by free-of-cost firmware
- Optional connection to sensors
- Optimized and built for use with ebusd
