Leonardo DE PALO
  • 1 Projects
  • 1 Followers
  • Feb 18,2025
A cheap joint motor driven by Theremino System under Windows
A 12 Volt DC motor with worm geared reduction, that have the speed of 6 rpm on the exit shasf, with H bridge MOSFET driver encoder onthe exit shaft and a Theremino Master to be conect over Hugh speed USB to Windows 10 PC. The software to control the movement is Theremino Automation. {this description need to be more accurate, will be in the next hours}
33
2
  • Like( 2 )
