cris
  • 74 Projects
  • 22 Followers
  • Oct 13,2024
8x8 LED Matrix Circuit using 74HC595
I have a small 2*2cm 8x8 LED Matrix, so I made a circuit for it.
  • SN74HC595
  • Kicad
I drew this circuit out of the need to reduce the number of connections to the Arduino platform, it uses 2 shift registers 74HC595 together with 8 current limiting resistors. It can be seen as an alternative to circuit with MAX7219. It works quite well for a 2*2cm 8x8 LED matrix.
Note: The matrix used in this circuit is very small, probably the smallest version made.
P.S. I am not the original author of this circuit, I just draw it.
18.6k
14
  • Like( 14 )
