LEDS are so popular among our life that you could see them almost everywhere. And this product is inexpensive but very helpful. Today I wanna introduce following projects about leds which are really fascinating and distinctive.
JolliCube (8x8x8 LED Cube) With MD_Cubo Library
This is a beautiful led cube ! First of all, you need to design electronic control circuit and arrange leds for your cube. Next, you can build the jigs. For the assembly part, you can build 8 layers of 8×8 led matrix and then complete the led cube with control circuit.
jolliCube - 8x8x8 LED Cube Assembly Part
Arduino Controlled Positional RGB LED Christmas Tree
This project is practical for Christmas Day,and you can make christmas tree shine yourself. First you are supposed to test your lights before usage and then assess the voltage drop. Next, you can color your RGB strip for its colorful beauty. Finally you could hang your lights up and determine positions. When you run it ,you can also modify the code.
Creating An Audio-Reactive LED Circuit
It is quite easy if you take actions and prepare materials enough. After calculating resistors value you can power the breadboard and leds. Next you can add the transistor and connect the audio cable to see whether the led flash with the audio. Start the music and enjoy the show!
LED strip Synced MUSIC
Similar to above project, leds could dance on music too in this project which is very interesting and awesome. But in this project you need a led strip which is about 5m long but if you have taken 2 or more led strips then you need to connect parallel to the first led strip.
If you gonna to make above projects you are reminded for following related materials
*^-^* Browse them for more choice~
[table id=25 /]
