This october is loaded with heavy harvest, making good farewell to shenzhen maker week and shenzhen maker faire as well as enjoying hot sales of new products in this month.So today I gonna introduce eight hot new arrivals in this month for your choice.
DIY Rotating LED Display Electronic Clock Module - Blue
shares display of electronic clock, date, time and temperature in turn
shares brilliant functions of timing, chiming and temperature alarming and so forth
enjoys over ten kinds of led display actions
DIY 4DOF Acrylic Robot Arm with Power Supply
a creative 180 degree rotating programmable desktop product
supports import and output action files and increases to 100 actions teams
controlled by android phones after adding HC-06/HC-04 Bluetooth modules
Raspberry Pi Lithium Power Supply Expansion Board
custom-made for raspberry pi to help it work as long as 9 hours
two USB-A connectors, one can supply power for pi board and if necessary another one could also supply power for LCD devices
shares powerful overload protection to protect raspberry pi and devices not to burn for short circuit
4WD Suspension Chassis Smart Shock Absorption Car
even from a half meter high place falling down it will not damage over the EMC detection of strong magnetic motor high interference
diy it to be ultrasonic smart car and wifi car
sent parts so please self assemble
TP101 Electronic Digital Thermometer
made in pen-type structure for convenient and portable use
made of stainless steel probe which is safer and more durable
available to various measured subjects including liquid,paste,oil,food processing,rubber and plastics processing at a wide range of -50℃~+300℃ (-58℉~+572℉)
16x32 RGB LED matrix panel + Arduino driver shield
Compatible with Adafruit’s
RGBMatrixPanel Library
features the DS1307 RTC chip on board along with a CR1220 coin-cell battery holder
comes with a RGB connector shield for Arduino Uno and necessary cables for easy wiring between the RGB panel and the Arduino board
3.6V Micro Hydro Generator(G1/4")
provides great electric current when on and off
supplies stable electric current to avoid not enough electricity
shares durable product lifelong which could be up to over 10,000 hours with high reliability
8mm Waterproof Android OTG Endoscope USB Inspection Snake Tube External Camera(5M)
supports computers and android phone which has OTG and UVC function
adjusts six led lights and record video to check the whole process for later observation and analysis
share wide applications in underwater camera,motor vehicle detector,the PCB detection, tractors industries and petroleum drilling industries and so on
There are
more waiting for you~
