Dragons, the mythical, legendary and magical creatures with their elegance and brilliance, have inspired man to create countless works of art for them. These majestic beings have always been associated with hidden treasures such as rubies, diamonds, emeralds, and gold, and have been revered for their powerful presence.
They are not only cool in mythical fictions, but also cool in the 3D printing industry, a cool dragon 3D print STL model can be an efficient way to test the working efficiency of a 3D printer and also an extraordinarily cool figurine for makers, otaku, and any figurine hobbyist to display on their figurine table.
The Cali-Dragon is a cute dragon 3D print model that is aesthetically stunning and cute, but also a fabulous 3D printable dragon design test model. In addition, the exquisite Cali-Dragon 3D printing requires many parameter adjustments to the slicer software in terms of overhangs, small perimeters, stringing, etc. You can evaluate your 3D printer print quality or improve your 3D printing software operation skills and improve your printer or slicer profile by choosing the cool dragon 3D print model to print.
The designer mentions that the model can be printed with no infill (0% density). One community member reported printing the model with 0.2-mm Z-Hop, 1.2-mm retraction distance, and 40-mm/s retraction speed.
Each stl model is designed with subtle efforts by its designer, as for the cute cali-dragon, it was designed by McGybeer, and you can find the STL file in 4 different stl websites, the links are listed below.
Cults: https://cults3d.com/en/3d-model/game/cali-dragon
Myminifactory: https://www.myminifactory.com/object/3d-print-cali-dragon-224509
Printables: https://www.printables.com/model/209121-cali-dragon
Thingiverse: https://www.thingiverse.com/thing:5401659
If you are someone who is really interested in an articulated masterpiece of a magical medieval monster, you can try 7Fish’s articulated dragon 3D print stl model. This aesthetic dragon is with intricate details, vivid, majestic and designed to have cloth wing inserts for the authentic folding experience.
This mythical creature is a large, scaly reptile with wings, sharp claws, and a long, powerful tail. If you are a maker good at post-processing for 3D print models, you can use acrylic coating to polish the 3D printed body with iridescent scales. Imagine having this dragon 3D print model that shimmers in the sunlight with large and leathery dragon wings allowing it to soar through the air with ease, it must be cool to display the dragon 3D print that is a fearsome predator with vivid claws and razor-sharp teeth.
Printing, finishing, and assembling this particular model can be a time-consuming process due to the number of small parts involved. It's worth noting that the STLs come with built-in supports that must be disabled in your slicer before printing.
In addition, the designer has created an updated version of the model with larger dimensions and revised joints. This revised model has garnered a lot of attention with over 65 shared creations and is quickly becoming a fan favorite.
You can find the STL model in the link below:
Thingiverse: https://www.thingiverse.com/thing:2884250
Sea serpents lack wings and legs but have amazing articulated tails, perfect for wrapping around precious objects or swimming through the vast oceans of legends and sailors' tales.
While this may be a time- and effort-consuming task, the shared prints indicate it's definitely worth it! There are built-in supports that facilitate printing, which should be done at a high resolution.
Author: 7Fish
Thingiverse: https://www.thingiverse.com/thing:2744865
Dragons are mythical creatures that have captured the imagination for centuries. They are often depicted as ferocious beasts with sharp claws, powerful wings, and the ability to breathe fire. In Western mythology, dragons are typically portrayed as malevolent creatures representing chaos and destruction, while in Eastern mythology, dragons are revered as symbols of good fortune, wisdom, and strength. These dragons are often associated with a variety of elemental and spiritual abilities.
These dragons are often associated with a variety of elemental and spiritual structures, making it an easy process to adjust the scale and resolution to your liking.
The Eastern Dragons, also known as "Long" in Chinese culture, are often depicted as serpentine creatures with long flowing manes, four legs, and no wings. They are believed to have control over the elements of nature and are often associated with water, a symbol of wealth and abundance in Chinese culture. But what makes this 3D print truly remarkable is its fully articulated form.
7Fish is a talented designer who has created numerous 3D models of dragons, including the 2 dragon 3D prints mentioned above. Created by the talented designer 7Fish, this Oriental Lung Dragon model is composed of numerous parts that require finishing and assembly. Fortunately, the designs come with built-in support structures, making it a hassle-free process to adjust the scale and resolution to your liking.
Author: 7Fish
Thingiverse: https://www.thingiverse.com/thing:3158246
If you are a fan of Jurassic World, the T-Rex Dragon 3D Print is the cool and scary dinosaur you want to have in your collection.
While it may not have the same level of mobility as the Articulated Serpent Dragon, the Flexi Trex is still flexible in movement. Its numerous joints allow for some flexibility and articulation in both the wings and the body. It's worth noting, however, that these types of joints may not hold position as well as ball joints.
One of the main advantages of the Flexi-Trex is its ease of printing. All joints are printed in place, and the entire 3D dragon print can be printed without any cumbersome steps.
Printing the Flexi Dragon isn't difficult either, as the designer has shared some settings that have worked for them. These settings include a layer height of 0.2 mm, an infill density of 20% or higher for a good top layer, and no need for supports or a raft.
Author: Benchy4Life
Thingiverse: https://www.thingiverse.com/thing:2893279
With its slimmer body and more developed spikes, this model is ideal for any number of uses, taking inspiration from the popular "Adalinda the Singing Serpent".
With a height of 130 mm, Aria prints without any supports.
Author: loubie
Thingiverse: https://www.thingiverse.com/thing:600550
In Pokémon, Dragonite is one of the most well-known characters, and you can make this cutesy 3D model of him. Moreover, this project features Dragonite in its upright, non-attack position with a sack across his stomach. The designer of this model did not provide much other information, but you can make it with just one print!
The creator of this Dragonite model did not provide any information about the settings they used, but some recording makers did. One posted an excellent print of the dragon model and mentioned that the layer height was 0.1 millimeters with a 30% infill density. In addition, the model was printed with supports.
Author: Patrickart
Printables: https://www.printables.com/model/181129-dragonitepokemon
Thingiverse: https://www.thingiverse.com/thing:3962846
You probably remember Toothless, the main dragon character from the How to Train Your Dragon animated movies and TV shows.
In total, there are six different parts to this adorable 3D dragon print, which can be printed in different colors to improve the look of the dragon. It features Toothless sitting down with his tongue sticking out. It consists of six different 3D printable parts.
Multi-color effects can be achieved by either printing different filament colors or using a multi-material unit (MMU) if you possess an MMU (Prusa Multi Material 2S Upgrade (MMU2S) on your printer.
A few community prints users commented that they activated supports when printing the dragon model and that the tail should be taken care of, as it is quite thin, but the creator did not provide any printing tips. However, these charming prints show that you can print Toothless and take him with you on your adventures!
Author: Derailed3D
Printables: https://www.printables.com/model/32814-toothless
Printing the cool dragon 3D print you want is fantastic, however, if you do not have a good 3D printer to help you accomplish it, you can resort to professional 3D printing services. Elecrow is a company good at providing professional online 3D printing services for makers Elecrow can do PCB assembly, PCB manufacturing, and component sourcing for makers to complete their wanted 3D printing DIY electronics project. If you want to create an acrylic display stand for your beloved dragon 3D prints, you can even resort to Elecrow's acrylic laser cutting services to complete your project.
By the way, if you are a maker who has fantastic ideas for some 3D printing projects and wants to complete them for commercial purposes but is worried that it will be hard to do so, contact Elecrow to join our partner seller program, Elecrow's partner seller program can help you mass produce your 3D printing projects and help you sell them online with a professional team.
Earn your benefits in Elecrow's Partner Seller Program!
