Can't believe another year has gone by. These are the most popular product of 2020, I think it is not enough for every customer. But stay tuned, more competitive new product will be launched in the future.
The resolution of the LCD display is 800 x 480, you can configure the resolution via software, the maximum resolution it supports is 1920 x 1080. It is a USB capacitive touch screen and does not require the driver.
It supports five touch control, besides that, the LCD screen comes with OSD menu adjustment function. You can adjust the contrast, brightness, switch button.
It is compatible with the latest Raspberry Pi 4B, BB Black, Banana Pi and other mini PC. Also can be used for SONY PS4, XBOX360 and Nintendo gamer.
When it used as a display for Raspberry Pi, it supports Raspbian, Ubuntu, WIN 10 IOT system, and supports single-touch control. When it used as a display for PC, it supports Windows 7/ 8/ 8.1/ 10, and supports five touch control.
This Micro:bit basic kit is created to help students get started with electronics and programming. It has frequently used DIY electronics parts and step-by-step lessons.
It includes 10 practical electronic projects, you can understand the electronics and obtain programming skills through hands-on learning.
No soldering required, just built your circuit on the breadboard.
This starter kit comes with the main components such as LCD1602 display,Step motor,Servo,Remote, touch sensor and Ultrasonic distance sensor, you can make some funny little builds by these things.
We will provide detailed and clear tutorial(PDF),there are 26 lessons for Raspberry Pi and 30 lessons for Arduino.
In the tutorial,there are clear steps in each lesson that include Overview,Specification,Pin defication,Connection diagram,Demo code,Complie & Run and Application effect for Raspberry Pi or Arduino.
Raspberry Pi GPIO development using the same as Arduino wiring language, easy to use.From a simple LED development gradually into the big project(Temperature and Humidity Monitoring Experiment,Water Level Monitoring Experiment and so on).
This OLED display module is small, only 0.96” diagonal, it is made of 128x64 individual blue OLED pixels, each one is turn on or off by the controller chip.
It works without backlight, that is, in a dark environment, OLED display is higher compared to that of LCD display, you will like the miniature for its crispness.
This module uses I2C to communicate with microcontroller such as Arduino.
The Nano V3.1 is a small, complete, and breadboard-friendly board based on the ATmega328 (Arduino Nano 3.0) or ATmega168 (Arduino Nano 2.x).It have an integrated on-board USB. As the function, It has almost all the analog and digital pins that the UNO or Duemilanove has and the same function as Duemilanove or UNO.
This Nano 328(Arduino compatible) can go with the IO Shield for Arduino Nano, it would be more friendly and convenient for users to enter the Arduino world and make use of Arduino to make their dream into reality.
As an upgrade version of Arduino Nano, This Nano V3.1 is 100% compatible to Arduino Nano and its shield and IDEs. On the hardware part, remarkable changes are taken to improve the flexibility and user experience.
This module based on the DS3231, it is the foreign high precision clock module for Raspberry Pi B+ and Arduino.
Device package and function compatible with the DS3231.Complete clock calendar functions including seconds, minutes, hours, day, date, month and year timing.
The module can adapt itself 3.3 V and 5 V system without level conversion, it is super convenient!
To 40℃ to + 85℃ temperature range, timing accuracy in a plus or minus 5 PPM (+/- 0.432 SEC/day).
CrowPi is an educational tool based on Raspberry Pi, designed to help people learn electronics, programming, and basic computer science.
The main purpose of CrowPi is to work as an educational tool, also we can use it as a small computer
Equipped with a 7 inch HD touchscreen along with a camera. All the regular components used in DIY electronics are packed into the CrowPi development board, such as LCD, LED matrix, buzzer, light sensor, PIR sensor, ultrasonic sensor, IR sensor, etc.
Used for STEM education, the self-developed software is mainly for learning Scratch, Python, AI, and Minecraft step-by-step via an engaging dialogue teaching mode. (For a better experience, we recommend using Raspberry Pi 4B 2G or above.)
Featuring with 22 kinds of sensors and modules for engineer your own electronics projects.
Can set it up as a laptop, with 11.6-inch 1920*1080 IPS screen, 2MP camera, microphone, and stereo output built-in.
Switch between projects using one button and get creative using Raspberry PI GPIO pins, all of which connect to the on-board sensors or function as independent outputs.
Abundant lessons to learn to code quickly, 32 python lessons to teach you to start coding with on-board sensors step by step from easy to difficult.
There are so many advantages of Crowpi2, please check out our video or product link to learn more
This is a capacitive soil moisture sensor, it can measure the soil moisture level of your plant by capacitive sensing.
Compared with other types of moisture sensor, the capacitive soil moisture sensor is made of a corrosion resistant material, which will provide a long service life. This moisture sensor can be used to detect the moisture of soil to monitor if the plants need water.
Arduino Automatic Smart Plant Watering Kit is based on Arduino Lenardo which has integrated into the mainboard. With a RTC to set timing watering and a 0.96 inch OLED to show the time and the soil moisture status.
The kit includes a pump, capacitive soil moisture sensors, water switch to redirect the water to up to 4 plants and pipes for the water to go through. Compared with the resistance moisture sensor, the soil moisture sensor is made of a corrosion resistant material, which will provide a long service life.
The Smart Watering Kit allows providing all your own smart plant monitoring system with ease of use and unlimited options!
The module is a PH sensor, which can be used to test PH value of the aqueous solution. The electrode of the Crowtail PH sensor is a composite electrode which composed of glass electrode and reference electrode.
It is widely used in environmental monitoring, chemical industry, pharmaceutical industry, dyestuff industry, universities and research institutions in the situation of detection the pH of aqueous solution.
This LCD module is 800x480 dots 7 " color TFT LCD module display with HDMI, VGA, Video, AV signal driver board, superior display quality, super wide view angle.
It can be used in any embedded system, car, industrial device, security and hand-held equipment which requires display in high quality and colorful video.
Its HDMI interface is fully compatible with Raspberry PI, pcduino and Banana Pi platform.
Thanks for your support all the time and you’ll see the improvements next year!
