Holiday Notice: Elecrow will be on holiday starting January 26th (GMT+8).
the last shipment day for service orders is January 21st.
Orders can still be placed during the holiday, but deliveries will be delayed. [Learn More]
Have you felt confused when you want to make something different but you don't have the suitable tools for use? Or have you found that if you own some special tools to make projects it will seem more powerful and fantastic. So please allow me here to share you featured hand tools and electric tools for your projects and I believe you must find one you fancy a lot.
Hand tools Mini DIY Table Saw Bench for PCB Acrylic Wood
ideal for processing model and your diy works
easy to cut PCB, Acrylic, Wood these materials etc
Precise machining with ruler with high concentricity
BEST 38-In-1 Interchangeable Precise Screwdriver Set
36 different interchangeable heads,an Extension rod and a comfortable rubberized handle for various purposes and different precision tasks such as mobile phone or watch repairs etc
Auxiliary Clip Magnifier for Soldering
Useful maintenance tool with magnifier, clip, LED and iron stand
Great use for welding small SMD components
Electric toolsMini Electric drill kits
Kit for drilling, grinding, cutting, polishing, engraving etc
Come with a complete assortment of sanding drums, diamond wheels, brushes, sanding discs, wire brushes, twist drills etc
The speed of the Electric Mini Drill can be adjusted to 1 – 6 grade
DS202- Digital Storage Oscilloscope with Touch Screen
Easily operated with the gestures of one-click, double-click, press and slide
More stable hardware and other better specifications for your electronic measurement than the DS201
Portable, small and inexpensive with abundant functions
Acrylic Bender 100v-240v AC
Ideal for regular heating on acrylic luminous characters
Adopt PTC heating set for energy-saving, fast-heating, safety, longer life-span and auto constant temperature
Make the regula melt in short time without smoke during heating
Certainly there are also many other helpful tools for your choice, welcome to click here to browse for details.
