The Elecrow Starter kit for Micro: bit is designed for people who are at the doorstep of learning electric modules and programming knowledge and bring numerous creative possibilities for you to dig out and help you enter a wonderful electronic world.
This kit includes more than 20 modules like the buzzer, light sensor, servo, ultrasonic ranging sensor, and OLED, etc. The kit also provides you plenty of fun experiments so you can learn how the electric modules work and use it to build innovative works and plan out unique projects.
In addition, the kit also focuses on stimulating children's creativity so that they can continue to move forward rather than stagnate after completing their work. We never allow complicated jumpers to prevent children from learning about the electronic world and programming hobbies and interests, and we vowed to change it.
Therefore, we have equipped this starter kit for Micro: bit with our plug-and-play crowtail series of electronic modules to make you realize the electronic works in the mind quickly and easily.
Get to know Micro: bit
Micro: bit is a pocket-sized computer that lets you get creative with digital technology. You can code, customize and control your Micro: bit from anywhere! You can use your Micro: bit for all sorts of unique creations, from robots to musical instruments, the possibilities are infinite. The Micro: bit compatible with a number of online code editors across a number of different languages, such as Blocks, JavaScript, Python, Scratch, and etc.
Crowtail-Base shield for Micro:bit
The Crowtail-Base shield for Micro: bit is the core part of this kit, it acts as a bridge between Micro: bit board and Crowtail modules. You can plug and then play with Crowtail modules and Micro: bit through this base shield, which allows you to create more interesting and innovative works with Micro: bit. This shield integrated 6 crowtail connectors and 2 crowtail UART/I2C connectors onboard. So you can use plenty of crowtail sensors. All you need to know is that there is no need for any soldering or jump wire about Crowtail.
In addition, there is a power port, from which you can draw 3.3V/5V/12V three voltages! This means that when you use a module such as a motor, you no longer need an external drive!
What is Crowtail?
Crowtail is a modular, ready-to-use toolset, it takes a building block approach to assemble electronics. It simplifies and condenses the learning process significantly. In our Crowtail repository, there are over 150 Crowtail modules and Crowtail shields!
The Crowtail products are basic-functional modules that consist of a Base Shield and various modules with standardized connectors, each Crowtail module has its specific functions, such as light sensing and temperature sensing. It will satisfy all you need for your project!
Crowtail is a series of products that we made to solve the messy jumper when connecting electronic circuits. It consists of a Base Shield and some basic Crowtail modules, which help you create small, simple, and easy-to-assemble circuits. In other words, when you use Crowtail, your electronic project will not be messy wiring. Instead, it will be simple and easy to manage an electronic project!
Hope you like our Crowtail Starter kit for Micro: bit, stay tuned for more exciting Learning KIT that will be coming up in the future.
