Make a calculator on CrowPi
My neighbor has a little girl with bad arithmetic. This is a headache when her parents direct her arithmetic, so I want to use Crowpi to program a simple calculator to help people who are not good at computing. My idea is to use the 4  independent buttons on Crowpi as +, - , *, /, and then use the 10 buttons on the matrix button to do 0-9 respectively.When I press these buttons, Crowpi Lcd can display the contents of the button I pressed. When I want to get the result, just touch the touch sensor and it will automatically display the result on the LCD.
With the basic ideas, let's get started. Of course, the first thing to do is always to import the modules we want to use. import math import time import RPi.GPIO as GPIO import Adafruit_CharLCD as LCD
Then we need to set the mode of GPIO. After setting this mode, the GPIO number and the physical pin number on the Raspberry Pi board are corresponding.
# set GPIO board mode
GPIO.setmode(GPIO.BOARD)
Then create two lists to distinguish the independent key data and the matrix key data, initialize the lcd, and then set the id of the matrix button and the corresponding GPIO port of the row and column.
a=[]
b=[]
# matrix button id # define LCD column and row size for 16x2 LCD
lcd_columns=16
lcd_rows=2
# initialize the LCD using the pins
lcd=LCD.Adafruit_CharLCDBackpack(address=0x21)
buttonIDs=[[1,2,3,4],[5,6,7,8],[9,0]]
# gpio input for rows
rowPins=[13,15,29,31]
# gpio outputs for columns
columnPins=[33,35,37,22]
# define four inputs with pull up resistor
for i in range(len(rowPins)):
    GPIO.setup(rowPins[i], GPIO.IN, pull_up_down = GPIO.PUD_UP)
    # define four outputs and set to high
    for j in range(len(columnPins)):
        GPIO.setup(columnPins[j], GPIO.OUT)
        GPIO.output(columnPins[j], 1)
In the activateButton () function, we get what the button is pressed and display it on the lcd, then add the pressed button value to the a list.
def activateButton( rowPin, colPin):
    # get the button index
    btnIndex = buttonIDs[rowPin][colPin] - 1
    lcd.message('{0}'.format(btnIndex+1))
    a.append(btnIndex+1)
    return btnIndex+1
In the indeButton () function, we need to define the gpio of the button, and what is represented when the different GPIO port buttons are pressed and displayed on the lcd, and finally add the button value to the b list. def indeButtons():
    buttons = [37,33,35,22]
    for button in buttons:
        GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        if(GPIO.input(button) == 0):
            if(button==37):
                button='+'
            elif(button==33):
                button='-'
            elif(button==22):
                button='*'
            else:
                button='/'
            lcd.message('{0}'.format(button))
            b.append(button)
            time.sleep(0.5)
            return button
In the matrixButtons () function, we will set the mode of the matrix button to determine if the button has been pressed, if it is pressed, call the activateButton function (display the pressed button and add it to the a list), and finally restore the button state.
def matrixButtons():
     # initial the button matrix
     while(True):
             GPIO.setup(columnPins[j],GPIO.OUT)
             # set each output pin to low
             GPIO.output(columnPins[j],0)
                 if GPIO.input(rowPins[i]) == 0:
                     # button pressed, activate it
                     activateButton(i,j)
                     # do nothing while button is being held down
                     while(buttonHeldDown(i)):
                         pass
                     break
              # return each output pin to high
             GPIO.output(columnPins[j],1)
         break
I define four mathematical operations that correspond to independent buttons. add(), sub(), mul(), div()  functions to calculate the number we input.
In the touch () function, set the pin port corresponding to the touch sensor, and then judge, if the touch is detected, display the "=" number on the lcd and call the corresponding operation method according to the input independent button and output the result, and finally the result. Add to the a list for the next operation.
def touch():
    # define touch pin
    touch_pin = 11
    #set GPIO pin to INPUT
    GPIO.setup(touch_pin,GPIO.IN)#,pull_up_down=GPIO.PUD_UP)
    # check if touch detected
    if(GPIO.input(touch_pin)):
        lcd.message('=')
        if(indeButtons):
            if(b[-1]=='+'):
                count=add(a)
            elif(b[-1]=='-'):
                count=sub(a)
            elif(b[-1]=="*"):
                count=mul(a)
            else:
                count=div(a)
        a.append(count)
        lcd.message('{0}'.format(count))
    time.sleep(0.5)
[caption id="attachment_5159" align="alignnone" width="300"]IMG_2372 Run image[/caption]
This is all about making a simple calculator on Crowpi. Note that the program can only run single-bit operations. If you want to perfect it, start your brain to make him stronger! Below is the complete code for the program.
import math
import time
a=[]
b=[]
lcd_columns=16
lcd_rows=2
    return btnIndex+1
def buttonHeldDown(pin):
    if(GPIO.input(rowPins[pin]) == 0):
        return True
        return False
def indeButtons():
            if(button==37):
                button='+'
            elif(button==33):
                button='-'
            elif(button==22):
                button='*'
            else:
                button='/'
            b.append(button)
            time.sleep(0.5)
            return button
     while(True):
                     activateButton(i,j)
                  #   print("button " + str(activateButton) + "pressed")
                  #   lcd.message('{0}'.format(activateButton))
                         pass
                     break
         break
def add(a):
    count=a[-2]+a[-1]
    return count
def sub(a):
    count=a[-2]-a[-1]
    return count
def mul(a):
    count=a[-2]*a[-1]
    return count
def div(a):
    count=a[-2]/a[-1]
    return count
def touch():
    # define touch pin
    touch_pin = 11
        lcd.message('=')
        if(indeButtons):
            if(b[-1]=='+'):
                count=add(a)
            elif(b[-1]=='-'):
                count=sub(a)
            elif(b[-1]=="*"):
                count=mul(a)
            else:
                count=div(a)
        a.append(count)
    time.sleep(0.5)
try:
    while True:
        lcd.set_backlight(0)
        matrixButtons()
        indeButtons()
        touch()
except KeyboardInterrupt:
    lcd.clear()
    lcd.set_backlight(1)
    cleanup()
