Raspberry Pi is also known as single-board computer, which is based on an ARM microcomputer motherboard and its size is similar to credit card, but it with all the basic functions of the computer. Since its advent, it has a lot of fans who is maker and computer enthusiasts. Although it looks small, its heart is very strong. If you want to learn more about raspberry pi functions and interface types etc, you can refer to the wiki.
There are a lot of the makers sharing their raspberry pi projects on the instructable. For most of the maker,
the raspberry pi screen is they will buy the goods. It can be applied to various occasions to achieve the data presentation function. In addition to raspberry pi official screen, the following screens can also be applied to raspberry pi.
- 7 inch 1024*600 HDMI LCD Display with Touch Screen
It uses
capacitive touch control with resolutions up to 1024*600. For your convenience to transplant system, the designer uses the standard HID protocol. In addition, it can work perfectly fine with Raspberry Pi and support Raspbian, Wbuntu, Windows 10 lot, single touch as well as free drive. On the other hand, when you used it as a computer monitor, it support for Windows 10/8.1/8/7, five touch and also free drive.
HDMI interface of the display to display and
the USB interface for touch function.
Click to buy:
https://www.elecrow.com/7-inch-1024-600-hdmi-lcd-display-with-touch-screen.html
- 4 Inch HD 480x320 TFT Display with Touch Screen for Rapberry Pi
Compared with 7 inch 1024*600 HDMI LCD Display, it looks mini small and its display type is TFT. It uses the SPI interface and support access to Raspberry Pi B+/ 2B/ 3B, etc. Similarly, it is not only for mini-PCs, but also can work as a computer monitor. This display has advantages of high brightness, high contrast and high responsiveness, etc. So this is a high cost-performance product.
Click to buy:
https://www.elecrow.com/4-inch-hd-480x320-tft-display-with-touch-screen-for-rapberry-pi.html
- 3.95 Inch TFT Display for Raspberry Pi
This
TFT LCD display is designed for RPI B and B+, you can use it to do many design. It is easy to use that play and plug. It can work well with your raspberry pi projects as long as simple connect to raspberry pi.
Read more details:
https://www.elecrow.com/395-inch-tft-display-for-raspberry-pi-p-1414.html
- 3.5 Inch 480x320 TFT Display with Touch Screen for Raspberry Pi
It is the little display for the Raspberry Pi. It uses the resistive touch overlay with 480*320 16-bits color pixels. It can compatible with Raspberry Pi A, B, A+, B+, and Pi 2/3 versions and adapt for Raspbian system. Besides, it can power from your computer or your portable power. Compared with other screen, it is a relatively thin.
Read more details:
https://www.elecrow.com/35-inch-480x320-tft-display-with-touch-screen-for-raspberry-pi-p-1385.html
- 10.1 inch 1280*800 IPS HDMI LCD Display(with case) for Raspberry Pi
This is the latest 10.1 inch screen of raspberry pi. It uses
HDMI interface and compatible with many occasions, such as supports banana pi, BB black. In addition, its backlight brightness can be adjusted to reduce power consumption. If you want this screen work together with raspberry pi, you need to manually set the resolution that edit the config .txt file of TF card root directory to set. Compared with other screens, its price is more expensive.
Click to buy:
https://www.elecrow.com/10-1-inch-1280-800-ips-hdmi-lcd-display-with-case-for-raspberry-pi.html
The above screens include touch function and the user can buy according to the requirement of their experiment.
And the following screens are without touch function:
- 7'' Inch 1280x800 HDMI/VGA/PAL Display
The display performance is very high, which can automatically detect your input and switch to the input port. Its resolution is 1200*800, but can be up to 1920:1080. It works perfectly when connected to a Raspberry Pi, but it will also work connected to any device with HDMI, VGA or NTSC/PAL output, such as PC, Notebook or even Camera. This screen doesn’t contain touch function.
Click to buy:
https://www.elecrow.com/71280x800-hdmivgapal-display-p-720.html
- 10.1 Inch Portable HD Display for Raspberry Pi 3
It is brand-new LED LCD screen with many interfaces of HDMI+VGA+AV+TV+USB. You could apply it as computer monitor, video monitor, PS3/4/XBOX game display and video player and so on. Moreover, the 10.1 inch HD display runs with high resolution, audio, remote- control and stereo speaker at a wide range of -30℃to +50℃working environment temperature which all could share you comfortable and convenient using experience.
Click to buy:
https://www.elecrow.com/10-1-inch-portable-hd-display-for-raspberry-pi-3.html
- Cheapest 7" 1024x600 HDMI/VGA/AV Display for Raspberry Pi B/B+/2B/3B
It is easy to use that simply connect the 12VDC adapter to the 2.1mm center-positive DC jack, then connect a digital video source to one of the ports. In addition, it can connect any device with HDMI interface, such as raspberry pi, banana pi and pcduino. The biggest difference is that it can work when you plug it on the device without any software support. Its power consumption is less than 6W and the input voltage in 11-13VDC.
Click to buy:
https://www.elecrow.com/cheapest-7-800x600-hdmi-display-for-raspberry-pi-bb-p-1455.html
