Are you tired of working on a single screen? Do you wish you had more screen real estate to increase your productivity? Whether you're a busy professional, a student, or a digital enthusiast, having the right display device can make all the difference. That's why we're excited to introduce Elecrow's newest monitor extender product, the CrowView 14'' Portable Dual Monitor, which will be launched on a crowdfunding campaign on Kickstarter soon.
The CrowView 14" FHD 1080P IPS Mechanical Clamping Dual Display Portable Monitor is a revolutionary monitor extender that will change the way you work, play and create.
Designed specifically for laptops, this clamp-on portable monitor provides users with a perfect dual-screen experience. Made of lightweight and ultra-thin engineering plastic material, it offers portability and an excellent touch feel, making your work faster and more efficient while improving work quality. The unique mechanical clamping structure, with adjustable retractable clamps and soft cushion clamps with three thickness direction limits, effectively prevents damage to the appearance of your laptop while providing a stable and secure structure. It also allows you to easily attach it to your laptop, giving you a fully functional dual-display setup wherever you go.
CrowView is compatible with mainstream laptop models ranging from 13" to 16.5" and a thickness of 8mm or less. It is also compatible with mainstream laptop operating systems such as Windows, Mac, Chrome, Linux, and Android, and can be used as an external display for gaming consoles such as Nintendo Switch, PS4, PS5, and Xbox. The product includes two full-function Type-C interfaces on the side, allowing for the dual-screen function with just one cable. It also provides power and display signal transmission between the laptop and the monitor without the need for an external power source. CrowView's low-power design helps reduce laptop power consumption.
Also, The CrowView 14" Portable Dual Monitor's anti-glare and 3H Hardness surface treatment protects your eyes and screen from scratches, while the external 5V-2A power supply and reserved interfaces ensure seamless connectivity and convenience.
Extensive Compatibility: Compatible with mainstream laptops on the market with screen sizes ranging from 13 to 16.5 inches, the CrowView is driver-free and compatible with popular operating systems such as Windows, Mac, Chrome, Linux and Android, and can also be used with gaming consoles such as Nintendo Switch, PS4, PS5, Xbox and some Android phones. With two built-in full-function Type-C ports, it supports plug-and-play functionality, creating a highly efficient dual-screen working environment.
Versatile Usage Scenarios: With its built-in metal hinge, the CrowView monitor can rotate in multiple directions and angles, allowing users to adjust its shape according to their needs. This versatile design allows for a variety of usage scenarios, as illustrated in the following images.
Mechanical Clamping Structure: The CrowView monitor features a unique adjustable and retractable clamping design that is simple to operate. The contact surfaces are covered with soft material, which effectively prevents damage to the appearance of your laptop while offering a stable and secure structure. The mechanical clamping structure also eliminates the need for additional support and helps to avoid overburdening or damaging the laptop's hinge. With the support stand, the monitor can be tilted at an appropriate angle, providing a comfortable viewing experience.
Lightweight Design: The CrowView monitor is made of injection-molded engineering plastic, resulting in a slim and compact design while ensuring the product's structural rigidity. Its lightweight and portable design makes it easy to move and carry, making it perfect for mobile work scenarios such as business meetings and document presentations.
High-Quality Display: The CrowView monitor features Full HD 1920x1080p resolution, an IPS panel for wide viewing angles, up to 400 nits brightness, 8-bit color depth and an A+ rated LCD module. The high-quality display provides clear and vibrant images, making it perfect for tasks that require precise and accurate color reproduction, such as graphic design and video editing. The wide viewing angles also make it easy to share your screen with others, making it ideal for presentations and teamwork.
Low power consumption: The CrowView monitor is designed with low-power hardware components specifically for laptops to reduce power consumption. It only requires a dual type-C cable to connect to your device and no additional power source is required. The monitor itself consumes only 4.8W of power, which means it can operate on a laptop for approximately 3-4 hours on a single charge. This power-saving design not only helps extend the battery life of your laptop but also makes the CrowView monitor an environmentally friendly choice.
Product size |
355x217x21mm |
Thickness |
10mm
Weight |
800g |
Screen Size |
14 inch
Panel Type |
IPS panel, wide viewing angle |
Resolution |
1920*1080p
Viewable area |
309.312*173.988mm
Brightness |
300~400nit |
Aspect ratio |
16:9 |
Refresh rate |
60Hz |
Color gamut |
72% NTSC |
Color depth |
8bit |
Contrast ratio |
800:1 |
Surface treatment |
Anti-glare, 3H hardness |
External power supply |
5V-2A, with power adapter |
Reserved interface |
a. Mini HDMI * 1; b. Type-C * 2 (full-featured and power supply); c. Headphone jack; |
Reserved buttons (on the back of the screen) |
a. Exit (return); (long press 3s, power on/off function) |
Indicator light (on the side of the screen)
Green light on: indicating that the product is in normal use; |
Supported Systems |
Windows/Mac/Chrome/Linux/Android; |
OSD menu: |
Built-in adjustment system, including brightness, contrast, image adjustment, color temperature adjustment, OSD settings, reset, and more; |
Touch Function |
Speaker |
Built-in battery |
jack |
3.5mm headphone jack |
CrowView is the perfect solution for a wide range of applications. Whether you're working on daily office tasks, giving presentations, traveling for work, editing videos, designing graphics and images, developing software or code, playing games, watching videos, or even trading stocks, CrowView enables you to work anywhere and get more done in less time.
CrowView is perfect for business professionals, graphic designers, stock traders, digital enthusiasts, frequent travelers, gamers, software developers, finance and accounting professionals, video editors, and anyone who needs to be productive on the go. It's also great for students who need to work on multiple projects at once or anyone who needs more screen real estate to get their work done. If you're looking for a tool that will dramatically improve your productivity and efficiency, CrowView is the perfect choice. Order yours today and experience the next level of productivity and efficiency no matter where you are or what you're working on!
The crowdfunding campaign for the CrowView 14'' Dual Monitor will start soon on kicksater.com. Stay tuned for updates and early bird specials. With CrowView's energy-saving design, broad compatibility, easy-to-use features, and high-pixel-count dual monitor, CrowView is the perfect solution for anyone looking to increase their productivity.
Don't miss your chance to support this exciting project and supercharge your work efficiency and enhance your work-from-home setup.
To learn more about the CrowView 14" Monitor Extender, please contact Elecrow for more information. And if you are interested in turning your own DIY electronics ideas into realistic products, but are worried about not having a professional team to support you, feel free to join Elecrow's Partner Seller Program, where you can earn money and mass-produce your DIY electronics products for commercial purposes.
