We're excited to announce the upcoming crowdfunding campaign to be launched on crowd supply for the CrowVision 11.6-inch touch screen, which is designed for a range of single-board computers, including Raspberry Pi, LattePanda, Beaglebone, Jetson Nano, and more.
The micro-switch is a switch that operates rapidly with a very small amount of force. The micro-switch is also called a miniature snap-action switch. It is extremely reliable, fast, and efficient to operate, and is also known as a miniature snap-action switch. It is impossible to create smart appliances without micro switches. They are used in many modern-day smart applications. Microswitches are often used as safety devices because of their reliability and sensitivity. They are used to prevent the closing of doors when something or someone is in the way and other similar applications.
With its long-range and low-power capabilities, The Lora modules have become a popular choice for a wide range of IoT applications. But what are Lora modules, and what are their advantages and disadvantages? In this blog, we will explore everything you need to know about the Lora modules. Whether you are an IoT enthusiast, a technical professional, or a curious learner, this blog will provide you with a comprehensive guide to the fascinating world
Are you an electronics enthusiast looking to expand your electronics project repertoire? Want to take your skills to the next level by exploring new and exciting products? Look no further than our list of five cool electronics products from partner sellers!
Whether you're interested in building your own smart home devices, experimenting with sensors, or creating your own robot, these products are sure to inspire you. They cover a lot of application areas, from loop detectors used to monitor vehicle count in parking garages to Arduino CNC shields used in
The Protoboard, also known as a Protoboard, solderless Protoboard, or terminal array board, is a type of building platform used to create semi-permanent prototypes of electronic circuits without soldering. Protoboards can be used over and over again because they don't need to be soldered or have their tracks destroyed, which is completely different from a stripboard (veroboard). As a result,
The Jetson Orin Nano 8GB module adds 1024 ampere-based CUDA cores to the 128 CUDA cores of the Nvidia Maxwell GPU. The additional cores and updated architecture mean that the Orin Nano delivers 80 times the AI performance of the Jetson Nano. The Jeston Orin Nano series starts with six Arm A78AE CPU cores, delivering nearly seven times the performance of the Jetson Nano. The Orin Nano uses the same AI architecture as the Jetson AGX Orin module but at a more affordable price.
Acrylic laser cutting is a precise cutting technique that utilizes a CAD file as a guide to cut a desired design from acrylic material. This process is a form of digital subtractive creation where the laser cuts or engraves the material with precision. Essentially, acrylic laser cutting is a highly accurate and efficient way to create intricate designs in acrylic material.
If you're a 3D printing enthusiast, you may have come across PET and PETG filaments. While these two types of plastic may sound similar, they are actually quite different. PET VS PETG, what are their differences? In this blog, we'll delve into the details and highlight the key differences between PET and PETG so you can make an informed decision about which material to use for your next 3D printing project.
The 3D Printer Metal filament is stronger, more durable when compared to regular plastic filament like PLA, knowing the best 3D Printer metal filament is essential for makers to complete electronics projects that require materials of high performance.
3D Printer Metal filament is a sort of material users can use for
When it comes to SBCs (Single Board Computers), you must know about Raspberry Pi, famous for its strong features, to other experienced makers, terms like Orange Pi, Banana Pi are also familiar, however, what is Rock Pi, and how about its product Rock Pi X?
Developed by the Radxa team, the Rock Pi X can be used as a Windows alternative to their Rock Pi 4. Featuring a quad-core x86 Intel Atom processor with up to 4 GB of RAM and 128 GB of onboard storage, the Rock Pi X comes in two models: A and B. The Rock Pi X A model has only the RJ-45 port and no wireless connectivity, while the B model has an 802.11ac WiFi + Bluetooth 4.2 LE module.
